Adding Identity Matrix to Matrix: Is 5 a Scalar?
  • Thread starter Thread starter thereddevils
    Identity Matrix
The discussion revolves around the addition of a matrix and a scalar, specifically questioning whether a scalar can be treated as a matrix by using the identity matrix. The subject area includes matrix operations and properties in linear algebra.
  • Participants explore the validity of adding a scalar to a matrix and whether the scalar can be represented as a multiple of the identity matrix. Questions arise about the dimensions of the identity matrix and the implications of adding matrices of different sizes.
The discussion includes various perspectives on the addition of scalars and matrices, with some participants asserting that such an operation is not defined. Others emphasize the importance of maintaining consistent dimensions when performing matrix operations. There is no explicit consensus, but several participants provide insights into the reasoning behind their views.
Some participants question the notation used to represent scalars and matrices, highlighting potential confusion in mathematical representation. The discussion also touches on the distinction between scalars and matrices, particularly in the context of addition and multiplication.
thereddevils
Say i have a matrix ,
[tex]\begin{bmatrix}{4}&{3}\\{-1}&{7}\end{bmatrix}+5[/tex]
is it correct if i do it this way ,
[tex]\begin{bmatrix}{4}&{3}\\{-1}&{7}\end{bmatrix}+5\begin{bmatrix}{1}&{0}\\{0}&{1}\end{bmatrix}[/tex]
[tex]=\begin{bmatrix}{9}&{3}\\{-1}&{12}\end{bmatrix}[/tex]
is 5 a scalar = 5I where I is an identity matrix ?
yes, I think you are correct
but one problem, how can you make a prediction about the size of that matrix as 2 x 2. I can say that the unit matrix is of 3 x 3 or 4 x 4 and then can you add?
thanks , how if we assume that the identity matrix is a 2x2 matrix ? since the given matrix is also a 2x2
btw , i have this question ,
is 0 = [tex]\begin{bmatrix}{0}&{0}\\{0}&{0}\end{bmatrix}[/tex] (zero matrix)
or 2 = [tex]\begin{bmatrix}{2}&{2}\\{2}&{2}\end{bmatrix}[/tex]
answer is yes for first, in the case of multiplication you can consider but when have to add you can't do it because you can only add it when both the matrix is of same order. To multiply any matrix with any scalar you have to multiply every term inside the matrix by that scalar.
Also I'm not sure whether 2 = [tex] \begin{bmatrix}{2}&{2}\\{2}&{2}\end{bmatrix}[/tex]
In my view it is wrong to write.
No, in general the sum of a vector or matrix and a scalar is simply not defined. "A+ 5" where A is a matrix makes no sense. Writing "5" or any other scalar to indicate a matrix is very bad notation. If it is intended to be interpreted as "A+ 5I" then it should be written that way.
It would be better to write 0 = [tex]\begin{bmatrix}0 & 0 \\ 0 & 0\end{bmatrix}[/tex] where I have specifically used bold face for the "0" to indicate it is NOT a scalar but a matrix.
In general, the 0 matrix is NOT equal to the 0 scalar. A scalar is not, and cannot be equal to, a matrix.
I need verification for my view from another members here. I think matrix is not any number like determinant. It is only a set of data so it is meaningless to add or subtract it by any scalar cause addition and subtraction is only done between two quantities having same dimension. Like you can't add velocity and displacement similarly you can't add matrix and scalar. One can add determinant with scalar cause it is also a number which can be found upon its solution.
thanks all for helping , i got it !
Right -- a matrix and a number are different. As HallsOfIvy said in his post, it is meaningless to add a scalar (number) and a matrix.
The addition problem posed in the OP is meaningless.
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 33 ·
  • · Replies 31 ·
