Thread Closed
Doppler Effect: Moving Observer riding on moving source! With reflection off wall!
Share Thread Thread Tools
Mar11-10, 07:06 PM   #1
A bus is moving at 37.00m/s towards a wall. The sound from the bus has an original wavelength of 0.1500m. The sound from the bus reflects off the wall. What frequency sound does an observer on the moving bus hear from the reflection??
2. Relevant equations
Moving Observer: fo = fs (1 + vo/v)
v = LaTeX Code: \\lambda f
3. The attempt at a solution
Is this doppler effect??
vo = 37.00m/s
Since v = LaTeX Code: \\lambda f
vi = LaTeX Code: \\lambda fi
f = v / LaTeX Code: \\lambda
= (343m/s)(0.1500) = 2286.667hz
Subbing into equation:
fo = (2286.667hz)(1 + 37m/s / 343m/s) = 2533hz
Ok, I ALSO tried another method...
Vs = 37 m/s
Therefore the speed of the wavefront is: vs + v
where v = 343m/s (speed of sound in air)
fs = 343m/s / 0.15m = 2286.667hz
Frequency observed is thus:
(v+vs/v-vs)fs = (343+37 / 343-37) (2286.667) = 2839.65hz
Both of these answers are choices in the multiple choice part, so this is becoming a frustrating question for me.
Help appreciated! Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar11-10, 11:46 PM   #2
The frequency of source does not change on reflection. Could you explain the thought behind your assumption in the first part?
Mar12-10, 10:33 AM   #3
Quote by aim1732 View Post
I was confused about that too, but am now thinking I misread some of my notes... which would explain A LOT of why that didn't make sense to me.
Could you check my two possible solutions and let me know if either is correct?
Mar12-10, 10:43 PM   #4
Well the second one is right.
I was thinking if frequency and velocity of propogation of sound do not change in reflection wavelength shouldn't change too.
Thread Closed
Thread Tools
Similar Threads for: Doppler Effect: Moving Observer riding on moving source! With reflection off wall!
Thread Forum Replies
Relativity - Doppler effect in reflection from a moving mirror Advanced Physics Homework 0
Frequency involving moving observer and source Introductory Physics Homework 2
Doppler Effect (moving source, moving listener) Introductory Physics Homework 3
Doppler Effect II (Both observer and source in motion) Introductory Physics Homework 4
Doppler effect: Moving source with reflection Introductory Physics Homework 4
