Conservation of engery of a pulley system
The discussion focuses on the conservation of energy in a pulley system involving two masses, m1 = 4.50 kg and m2 = 3.00 kg, connected by a light string over a frictionless pulley. The problem requires calculating the speed of the 3.00 kg object just as the 4.50 kg object hits the ground, yielding a speed of 4.43 m/s, and determining the maximum height to which the 3.00 kg object rises, which is 5 m. The isolated system model is applied, utilizing the equations of kinetic and potential energy to demonstrate that the final velocities of both masses are equal at the moment of impact.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of kinetic energy (KE) and potential energy (PE)
  • Knowledge of the law of conservation of energy
  • Basic algebra for solving equations
  • Study the principles of Newton's second law of motion
  • Learn about energy conservation in mechanical systems
  • Explore the concept of tension in pulley systems
  • Investigate the effects of friction in real-world pulley systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of energy conservation in pulley systems.
jwxie
Two objects, m1 = 4.50 kg and m2 = 3.00 kg, are connected by a light string passing over a light frictionless pulley as shown in the figure below. The object of mass 4.50 kg is released from rest, h = 3.00 m above the ground.
(a) Using the isolated system model, determine the speed of the 3.00 kg object just as the 4.50 kg object hits the ground.
(ans: 4.43)
(b) Find the maximum height to which the 3.00 kg object rises.
(ans: 5)
[tex]\Delta K[/tex] = - [tex]\Delta Ug[/text]<br /> mgy - mgyf = - [tex]\Delta Ug[/text]<br /> KEi + PEi = KEf + PEf<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> I know I can solve problem a differently. Suppose I solve each mass separately using law of conservation of energy, I can find Vf for mass 2 separately.<br /> <br /> Since the system is connected by the same uniform massless string, so the accerlation must the same. But I did not assume their Vf will be the same (the impact of m1 as it hits the ground, and at that instant the Vf of m2 raising to 4 meter).<br /> <br /> What I want to know is, how do you prove that the final velocity of m1 and m2 at that same instant is the same using the isolated system model KEf + PEf = KEi + PEi ?<br /> <br /> I have the following data on my hands<br /> <br /> for m2, where m= m2, h = 4<br /> _________________________<br /> | | KE | PE |<br /> | i | 0 | 0 |<br /> | f | 1/2mv^2 | m2h |for m1 where m = m1, h = 4<br /> | | KE | PE |<br /> | i | 1/2mv^2 | mgh |<br /> | f | 0 | 0 |[/tex][/tex]
Since the string is unstretchable, if m1 moves a small distance Δx in time Δt, m2 also moves the same distance in same time interval. So vf of m1 is the same as vf of m2.
Hi, thank you.
13K
