Register to reply
Electron diffraction
by quietrain
Tags: diffraction, electron
Share this thread:
quietrain
#1
Mar12-10, 05:55 AM
P: 651
ok, i did a lab and found values of the diameter of the electron rings after diffraction from a graphite. i also have the voltage that i accelerate the electrons to hit the graphite.
so to find the distance between adjacent planes of graphite carbon "d", we use bragg's diffraction law right? 2dsin(theta) = n(lamda)
but the problem is what if i need to find the interatomic distance "a" between the carbon atoms on the same plane. is there some sort of equation or law i can use to find this distance from the experiment data that i obtained above? i don't seem to recall any.
and also, am i right to say, the outer diffraction ring is caused by the diffraction between atoms of the same plane (interatomic) whereas the inner diffraction ring is caused by the diffraction between layers of atoms "d" given by bragg's law?
thanks a ton!
Phys.Org News Partner Physics news on Phys.org
Technique simplifies the creation of high-tech crystals
Working group explores the 'frustration' of spin glasses
New analysis of oxide glass structures could guide the forecasting of melt formation in planetary interiors
quietrain
#2
Mar14-10, 03:44 AM
P: 651
maybe i rephrase my question
ok, we use bragg's law to determine the spacing d between LAYERS of graphite
but how do we determine the interatomic spacing A between the individual Carbon atoms for each plane of individual graphite?
anyone knows?
Modey3
#3
Mar14-10, 06:42 PM
P: 136
quietrain,
Graphite is pretty simple when it comes to determining the structure-factor. I won't solve the problem for you, but try to represent graphite in terms of a orthorhombic unit-cell with a multi-atom basis. Find the structure-factor based on that symmetry. There is no easy "plug and chug" answer for this problem. Your going to need to do some work!
modey3
quietrain
#4
Mar15-10, 05:52 AM
P: 651
er i know the bond angles are 120 and the interatomic distance is around 0.142nm. but how do i get the interatomic distance from an experiment? i only have values for voltage, and the electron ring diffraction diameter only?
so with this 2 variables, i can find the interplanar distance d using bragg's law. but what about the interatomic distance? can i find it from just those 2 variables?
Modey3
#5
Mar15-10, 08:49 AM
P: 136
quietrain,
You will need to use more than just one diffraction ring to determine the inter-atomic distance. That's why you need to determine the structure-factor.
modey3
quietrain
#6
Mar16-10, 02:02 AM
P: 651
oh ya... i have 2 radius of diffraction rings... one bigger than the other... but i dont understand why there are two?
what is the structure? i only know that graphite is hexagonal in shape, so they have bond angles of 120?
but how does that allow me to find the interatomic distance?
Register to reply
Related Discussions
Electron Diffraction ? Quantum Physics 12
Electron Diffraction and Particle Diffraction Advanced Physics Homework 1
Electron diffraction Advanced Physics Homework 0
Electron diffraction Quantum Physics 15
A Q About Electron Diffraction General Physics 3
