Rotating loop in magnetic field
The discussion revolves around calculating the strength of a magnetic field (B) induced in a rotating rectangular wire loop measuring 20 cm × 30 cm, rotating at a uniform rate of ω = 50 rad/sec. The loop has a total resistance (R) of 36 Ω and an induced rms current of 0.04 A. To find B, participants reference Faraday's law of electromagnetic induction and the relationship between rms voltage and peak voltage. The calculated rms voltage is 1.44 V, which is essential for determining the magnetic field strength.
  • Understanding of Faraday's law of electromagnetic induction
  • Knowledge of peak voltage and rms voltage relationships
  • Familiarity with the concepts of magnetic flux
  • Basic principles of electromotive force (emf)
  • Study Faraday's law of electromagnetic induction in detail
  • Learn about the relationship between peak voltage and rms voltage
  • Explore calculations involving magnetic flux in rotating systems
  • Investigate the effects of resistance on induced current in circuits
Students studying electromagnetism, physics educators, and anyone interested in understanding the principles of induced currents in rotating magnetic fields.
Tekee
A single-turn rectangular wire loop of size 20 cm × 30 cm rotates at a uniform rate of ω = 50 rad/sec around the z-axis as shown. There is a uniform magnetic field B in the +y-direction. The loop has a total resistance of R = 36 Ω.
If the induced rms current in the loop is 0.04 A, what is the strength of the magnetic field B?
Unsure
I figure that the V will be .04 x 36, or 1.44 Amps. I know that there is probably an equation I can use where I can plug in emf, w, B, and A, although I have no idea what that is...
Tekee;2621503 [h2 said:
The Attempt at a Solution[/h2]
Multiplying 0.04 and 36 will give you the rms voltage. You want the peak voltage. How does the peak voltage 'V0' relate to the rms voltage 'Vrms'?
To get 'B', recall Faraday's law of electromagnetic induction. What would be the expression for the magnetic flux Φ?
  • · Replies 37 ·
