Minkowski 4-space? Yes or No.
  • Context: Graduate
  • Thread starter Thread starter stevmg
    Minkowski
The discussion revolves around the interpretation of an equation from Einstein's "Relativity" related to Lorentz transformations and its implications in the context of Minkowski 4-space. Participants explore whether this equation represents a parametric equation, the concept of world lines, and the geometric visualization of events in space-time.
  • Some participants assert that the equation describes a general mapping of space-time rather than a parametric equation, emphasizing its role in defining the space-time separation between events.
  • Others argue that the equation can be visualized as a four-dimensional cone, specifically the light cone, which delineates the possible relationships between events in space-time.
  • A participant questions whether the parametric depiction of world lines is a one-to-one function, suggesting that for each parameter, there is a unique value for each coordinate.
  • Some contributions clarify that events inside the light cone have a negative space-time interval, while those outside have a positive interval, and events on the cone are lightlike.
  • There is a discussion on the theoretical possibility of observing events in reverse order if one were to exist outside the light cone.
Participants express differing views on whether the equation represents a parametric equation and the nature of world lines. While some points are clarified, multiple competing interpretations remain unresolved.
Participants note that the equation's validity depends on the coordinates being measured relative to a common origin event, and there are unresolved aspects regarding the nature of parametric equations in this context.
This discussion may be of interest to those exploring concepts in special relativity, space-time geometry, and the mathematical representation of physical phenomena in four-dimensional space.
stevmg
In Einstein's "Relativity," this equation appears in Appendix I (Lorentz Transformations):
x1'2 + y1'2 + z1'2 - c2t1'2 = x12 + y12 + z12 - c2t2
This essentially says that for a given event at a given point and time in space, looking at this event from any frame of reference will give results that satisfy this equation for that event. In other words, x12 + y12 + z12 - c2t2 is a constant.
I assume that t is not a parameter but merely a coordinate, just as x, y and z are.
I am used to, from analytic geometery and linear algebra, that in the case of a parameter, once a value is assigned, will map to, simutaneously, all the coordinates and, since there is only one value in each coordinate that a given parametric value can map to, then we are essentially describing a line (straight or curvilinear) in space. The above equation, to my thinking, does not represent a parametric equation as the t can map to several x, y and z'sz once a value for it is assigned.
Do we jump off here to "world lines?" or is this completely different?
Hi stevmg! :smile:
That equation is not a parametric equation of a line or any other curve, it is a general equation mapping the whole of space-time onto itself.
It is a rotation in 4-space, just like any ordinary rotation in 3-space.
World-lines are completely different, they are curves in space-time (with "gradient" either always less than c, or always equal to c).
That equation is normally used to describe the fact that the magnitude of the space-time separation between two events in space-time does not depend on the frame of reference. The variables x,y,z,t are the displacements and time interval between the two events in one frame and the primed variables are the displacements and time interval as measured in any other frame.
Stevemg, since you're trying to visualize this in geometric terms, a good case to visualize is the one where these two expressions are both equal to zero. In that case you have the equation of a four-dimensional cone, which is the light cone: http://en.wikipedia.org/wiki/Light_cone
For that equation to hold for general events, the two sets of coordinates must both be measured relative to a common origin event. In that case, the space-time location of any event satisfies that equation; it says that the space-time distance between the event and the origin is independent of (special relativity) inertial reference frame.
The previous responses are correct. I will only add that it is certainly possible to write a parametric equation of a world line, e.g.:
[tex]\left(c t(\lambda), x(\lambda), y(\lambda), z(\lambda)\right)[/tex]
Where [itex]\lambda[/itex] is any arbitrary parameter, not necessarily equal to either coordinate or proper time.
Thank you for coming in, DaleSpam...
So the equation I presented is NOT a parametric equation after all (I thought not.) I like response #6 Jonathan Scott description of it. In other words, my description of that equation is correct - it describes an event in x, y, z and t and any and all combinations (4-tuples) of x, y, z and t which add up to the same value are merely ways describing that same event from another frame of reference. Sort of like x2 + y2 + z2 = 25. Any and all values of x, y and z (3-tuples) that satisfy that equation are points on a sphere of radius 5 and the center at the origin (0, 0, 0.)
Now, DaleSpam has defined a "world line" parameteric system using [tex]\lambda[/tex] as the arbitrary parameter (not necessarily a coordinate or point in time) that will define the world line or curve in space-time.
Question, as I am a little fuzzy on parametric equations: Is the parametric depiction a one-to-one function in which [tex]\lambda[/tex] is the domain for the coordinates (ct([tex]\lambda[/tex]), x([tex]\lambda[/tex], y([tex]\lambda[/tex]), z([tex]\lambda[/tex])) where each coordinate is the range? Again, if so, then what is defined would be some curvilinear line in, say, 4 dimensions (given those coordinates above). In other words, for each [tex]\lambda[/tex], there is only ONE value for each coordinate (of course, two different [tex]\lambda[/tex]'s can map to the same, say x, but not the other way around.)
I am aware of the "light cone" and I visualize it (using, say, just x and ct) as two lines crossing at the origin (like an "X") in which all points in the real world lie above the right ("/") land the left ("\") lines. It is not possible to to lie to the right or left of the "X" (outside the cone.)
If, by some miracle, one could get "outside the X" (outside the cone), then one could observe events happening in reverse order. In the real world, if event A precedes event B, this is true in all frames of reference and even in all the [tex]\tau[/tex] frames of reference(the frame of reference does not move, only time changes.) Getting "outside the cone" allows one to look at the "real world" and see event B precede event A.
Am I on the right track? Are there, theoretically, parametric systems of equations to describe all world lines which are "within the cone?"
That is all correct.
This is also esentialy correct. One other way to look at the light cone is in terms of the spacetime interval equation you gave in your OP: s² = x² + y² + z² - c²t². Events inside the cone will have a negative s² (aka timelike), events outside the cone will have a positive s² (aka spacelike), and events on the cone will have s²=0 (aka lightlike or null).
Yes, such a parametric equation is called timelike. That means that [itex](ds/d\lambda)^2<0[/itex]
Thanks...
Again, I am approaching my brain limit.
  • · Replies 51 ·
  • · Replies 17 ·
  • · Replies 16 ·
