Definitite integrals involving sin and cos.
The discussion revolves around evaluating definite integrals involving sine functions, specifically the integrals of the form \(\int^{\pi}_{0}\frac{1}{1+\sin\theta}d\theta\) and \(\int^{\pi}_{-\pi}\frac{1}{1+\sin\theta}d\theta\). Participants are exploring methods to approach these integrals, including complex analysis techniques.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using substitutions and complex variable techniques, such as \(z=e^{i\theta}\), to evaluate the integrals. There are attempts to relate the integrals to known forms and to understand the contributions of residues in the upper half-plane.
There is an ongoing exploration of different methods to evaluate the integrals. Some participants have offered hints and clarifications, while others are questioning the setup and assumptions of the integrals. The discussion remains active with no explicit consensus reached.
One participant notes a distinction between "solving equations" and "evaluating definite integrals," highlighting a potential misunderstanding in terminology. Additionally, there are concerns about the contour used in the complex analysis approach.
tuite
Hi!
I have learned how to solve equations like:
[tex]\int^{2\pi}_{0}\frac{1}{1+sin\theta}d\theta[/tex]
using
[tex]\int^{2\pi}_{0}F(sin\theta,cos\theta) d\theta[/tex]
[tex]\int_{C}F(\frac{z-z^{-1}}{2i},\frac{z+z^{-1}}{2}) \frac{dz}{iz}[/tex]
How do I solve equations of the type:
[tex]\int^{\pi}_{0}\frac{1}{1+sin\theta}d\theta[/tex]
and
[tex]\int^{\pi}_{-\pi}\frac{1}{1+sin\theta}d\theta[/tex]
Please help :-)
and
Please help :-)
The second one is reallly the exact same type as the one you know how to solve. To see this, just make the substitution [tex]\overbar{\theta}=\theta-\pi[/itex]<br /> <br /> As for the first one, draw a picture...Using [itex]z=e^{i\theta}[/itex], you should see that when you integrate from [itex]0[/itex] to [itex]\pi[/itex] you are integrating over the semi-circular arc in the upper half plane instead of integrating over the entire unit circle. So, the result is that only residues of the poles that lie inside the unit circle and are in the upper half-plane will contribute to the result.[/tex]
[tex] <br /> Ah! Great! The substitution explained for me! Thanks!<br /> <br /> Right now I'm struggling with:<br /> [tex]\int^{\pi}_{-\pi}\frac{1}{1+sin^{2}{\theta}}d\theta[/tex]<br /> <br /> when rewritten:<br /> <br /> [tex]\int_{C}\frac{1}{1+(\frac{z-z^{-1}}{2i})^2}\frac{dz}{iz}[/tex]<br /> [tex]\int_{C}\frac{4}{4-(z^2-2+\frac{1}{z^2})}\frac{dz}{iz}[/tex]<br /> <br /> which I get to<br /> <br /> [tex]\int_{C}\frac{4}{(6z-z^3-\frac{1}{z})i}dz[/tex]<br /> <br /> and then I'm stuck. <br /> Any hints?[/tex]
Multiply both the numerator and denominator by [itex]iz[/itex] and then factor the resulting denominator (use the quadratic equation)
The semi-contour is not a closed contour. That has to be fixed first before you can aply the residue theorem.
tuite said:
Hi!
using
A small point: You aren't "solving equations." You are evaluating definite integrals. An equation has an = in it.
  • · Replies 19 ·
  • · Replies 20 ·
