Inner product of Hilbert space functions
The discussion revolves around the properties of inner products in Hilbert spaces, particularly in the context of functions that may be zero almost everywhere except at isolated points. It references concepts from quantum mechanics and measure theory, exploring the implications of Lebesgue integration and the nature of functions in mathematical physics.
  • Some participants discuss the implications of the inner product being zero for functions that are zero almost everywhere, referencing Griffith's comments on Lebesgue integration.
  • One participant explains the definition of the Lebesgue integral and how it leads to the conclusion that functions differing on a set of measure zero can yield the same integral result.
  • Another participant highlights the relationship between quantum theory and functional analysis, specifically mentioning the space L^2(R^3) and its relevance to the Schrödinger equation.
  • There is a correction regarding the Dirac delta function, clarifying that it is not a function in the traditional sense and does not belong to L^2, contrasting it with the Kronecker delta.
  • Some participants suggest that functions may not be the most appropriate tools for certain mathematical descriptions, advocating for the use of equivalence classes of functions that differ on sets of measure zero.
  • Concerns are raised about the mathematical rigor in physics, particularly regarding how physicists handle concepts like the Dirac delta function.
Participants express a range of views on the nature of functions and integrals in the context of quantum mechanics and measure theory. There is no consensus on the best approach to defining inner products or the implications of Lebesgue integration, indicating ongoing debate and exploration of these concepts.
The discussion touches on the limitations of traditional function definitions in the context of measure theory and integration, particularly regarding sets of measure zero and the implications for defining inner products in Hilbert spaces.
Volvieras
this question is in reference to eq 3.9 and footnote 6 in griffith's intro to quantum mechanics
consider a function f(x). the inner product <f|f> = int [ |f(x)|^2 dx] which is zero only* when f(x) = 0
only points to footnote 6, where Griffith points out: "what about a function that is zero everywhere except a few isolated points? the integral would still vanish, although the function does not. if this bothers you, you should have been a math major"
now i actually am a math major, and am interested in the reasoning behind this.
does it have to do with the fact that you would be integrating the value of some function over a tiny amount of dx, which would then be somehow equated to zero in the limit that dx -> 0?
if that is the case, how does this hold up with the fact that the integral of the kroneker delta function is one? i.e int[delta(x-a) * f(x)] = f(a)
The definition of the Lebesgue integral is very roughly that you take a small range of possible values of the functions, and multiply one of those values with the "size" of the subset of the domain where the function has a value in that range, and then you add up the results. So if two functions have the same values on, say, the rational numbers, the integral of the difference between those functions is zero (because the size of the set of rational numbers is zero).
Because of this, you wouldn't get a Hilbert space if you take the set of square integrable functions and define a bilinear form on that space by
[tex]\langle f,g\rangle=\int f(x)^*g(x)dx[/tex]
It fails to satisfy
[tex]\langle f,f\rangle\Rightarrow f=0[/tex]
because we also have
[tex]\langle g,g\rangle=0[/tex]
where g is defined by g(x)=0 if x is irrational and g(x)=1 if x is rational. Note that this means that we didn't just fail to define a Hilbert space. We even failed to define an inner product.
The way out of this mess is to say that two functions are equivalent if they only differ on a set of Lebesgue measure zero, and then define a vector space structure and an inner product on the set of equivalence classes (and then verify that this space is complete).
That delta function is the Dirac delta, not the Kronecker delta, and that's a completely different story. It has nothing to do with Lebesgue integration. The actual definition of delta is
[tex]\delta(f)=f(0)[/tex]
The equation
[tex]f(0)=\int \delta(x)f(x)dx[/tex]
doesn't really mean anything on its own. The expression on the right isn't even an integral. It should be intepreted as a single symbol, defined to be equal to [itex]\delta(f)[/tex].[/itex]
Hello,
You've instinctively picked out the relationship between quantum theory and an area of mathematics called functional analysis, which in turn is based on measure theory and the analysis of metric spaces... as a math major you may be on this road already.
The relationship with quantum theory stems mostly from a particular function space called L^2(R^3), the space of all measurable functions on R^3 whose magnitude-square is Lebesgue integrable. This is a large space of functions; it includes all the continuous square-integrable functions. Yet, it is also the smallest extension of the continuous square-integrable functions which is "complete" in the sense of metric spaces. (In other words, L^2 is a Hilbert space.)
L^2(R^3) is the state space for the single-particle non-relativistic Schrödinger equation. The extension to field theory has been studied for decades but as far as I know it has never been fully worked out.
As @Fredrik said, Dirac delta is not a function and does not belong to L^2. Physics texts usually don't go into the details.
Cheers
Dave
As others have noted, Griffith was talking about Lebesgue integration. You might want to google that phrase, along with the phrases "almost everywhere" and "set of measure zero".
As you are math major, you almost surely will be required to take a class in analysis, where you will learn the joys of measure theory, Lebesgue integration, and a host of other topics. (BTW, "almost surely" is yet another of those measure theoretic keywords; you will run into this phrase if you take a course in probability theory (highly recommended).)
First off, that is the Dirac delta, not the Kroneker delta. Secondly, the Dirac delta "function" isn't a function. Thirdly, you have just found one of the key areas where mathematicians shake their heads with absolute disgust when they look at how physicists do math.
For a short, direct response:
Functions, simply put, are not the right tool for this job; they contain "too much" information: two different functions can both name the same mathematical object of interest.
(of course, functions are simply described, and can be used to name many objects of interest, so they are still worth studying)
An improved notion that is very often more useful is what Fredrik mentioned: we say that two functions name the same object iff they differ on a set of measure zero.
In addition to this thing with integrals, it cleans up some other quirks too -- e.g. the case of x=0 is no longer a relevant technicality when making a definition such as
f(x) = x/x​
And in particular, functions are not quite the right tool for the rather important job of describing "reality".
Even in the domain of classical physics, practically everything we "sense" is essentially an integrated response. I am using the word "sense" very broadly here: not only what we see, hear, feel, etc., but also what we measure with instruments. Go down to the domain of quantum mechanics, and those few things that do seem to be instantaneous or discrete measurements are in fact integrated responses.
  • · Replies 61 ·
  • · Replies 59 ·
  • · Replies 16 ·
  • · Replies 44 ·
