RC circuit - charge on capacitor after a long time
The discussion focuses on the behavior of an RC circuit with a 10V source, a 100-ohm resistor (R1), a second 100-ohm resistor (R2), and a 1uF capacitor. After a long time, the capacitor reaches saturation, resulting in a total equivalent resistance of 200 ohms and a steady current of 0.05A flowing through the circuit. The voltage across the capacitor is determined to be 5V due to voltage division, leading to a calculated charge of 5uC on the capacitor using the formula Q = CV.
  • Understanding of Ohm's Law
  • Familiarity with RC circuit behavior
  • Knowledge of capacitor charging equations
  • Basic concepts of voltage division in series circuits
  • Study the effects of varying capacitance on charge in RC circuits
  • Learn about transient response in RC circuits
  • Explore the implications of resistor values on current flow
  • Investigate the role of switches in circuit behavior over time
Electronics students, circuit designers, and anyone interested in understanding the dynamics of RC circuits and capacitor behavior over time.
Linus Pauling
RC circuit - charge on capacitor after a "long time"
Circuit: 10V goes to 100ohm resistor, then there's a branch point. One side leads to a a resistor R2 = 100ohms and the other to a capacitor with C = 1uF. The switch is located just before R1, and is closed for a "long time."
Solution: Ok, I first solved for the current through R1. After a long time, the capacitor becomes saturated with charge, so the current flows through R1 then R2 then back to the battery. Thus, R1 and R2 are in series and R_eq = 200ohms. By ohms law, the current must be the same through both resistors, I = V/R = 10V/200ohms = 0.05A.
Question: Now I am asked what the charge on the capacitor is in this situation (after a long time). The answer is 5uC. Can someone explain why?
an ideal capacitor is usually defined by:
Q = CV (charge on plates = capacitance * voltage across plates)
After a long time, when the capacitor is saturated with charge (as you said), we have 5V across the capacitor due to potential division between the two resistors (or applying ohms law to a resistor, if you like). So the charge on the capacitor is 5V * 1uF.
Hope this helps. :)
