Magnetic Field of Charged Capacitor: Calculating E & B Fields
The discussion revolves around calculating the electric and magnetic fields associated with a charging capacitor. The original poster presents a scenario involving a current of 0.450 A charging a capacitor with circular plates of 14.0 cm radius and a separation of 4.00 mm. The problem includes determining the rate of increase of the electric field and the magnetic field at a specific distance from the center of the plates.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive the rate of change of the electric field using relationships involving charge, capacitance, and current. Some participants question how to relate the magnetic field to the changing electric field, referencing Maxwell's equations and the Lorentz force law. Others explore the implications of symmetry in the capacitor's configuration and the appropriate use of integrals in the context of Ampere's law.
Participants are actively engaging with the problem, exploring various interpretations of Maxwell's equations and their application to the scenario. There is a mix of attempts to derive expressions for the magnetic field, with some participants providing corrections and alternative perspectives on the calculations. The discussion reflects a productive exchange of ideas, though no consensus has been reached regarding the final answer.
Participants note the complexity of relating the magnetic field to the electric field in this specific capacitor setup, with some expressing confusion about the definitions and parameters involved, particularly regarding the distance from the center of the plates versus the center of the capacitor configuration.
fedderenator
A 0.450 A current is charging a capacitor that has circular plates 14.0 cm in radius.
(a) If the plate separation is 4.00 mm, what is the time rate of increase of electric field between the plates? Answer: 8.26e5 MV/m/s
(b) What is the magnitude of the magnetic field between the plates 5.00 cm from the center?
Maxwell's Equations, Ampere's Law, Biot-Savart Law
(a) To solve this, I used the following process:
V = Ed = [tex]\frac{Q}{C}[/tex] [tex]\Rightarrow[/tex] E = [tex]\frac{Q}{Cd}[/tex]
[tex]\frac{dE}{dt}[/tex] = [tex]\frac{I}{Cd}[/tex] = [tex]\frac{I}{(\frac{\epsilon_{0}A}{d})d}[/tex] = [tex]\frac{I}{\epsilon_{0}A}[/tex]
(b) I really have no clue, but I would appreciate some help...
Which of Maxwell's equations gives B in terms of dE/dt?
Well, none of them really give B in terms of dE/dt, but the equation
[tex]\oint(Bds)[/tex] = [tex]\mu_{0}I + \epsilon_{0}\mu_{0}\frac{d\Phi_{E}}{dt}[/tex]...
gives B in terms of electric flux...
and then also, the Lorentz force law also describes a relationship between B and E fields...
F = q(E + vB)...
That's the one you want. If you imagine a small circle perpendicular to the plates of the capacitor, can you write the flux term in terms of dE/dt? You'll have to use the symmetry of the situation to get rid of the integral.
so would it be dE/dt*A where A is the circular area of the plates...and then int(ds) would be the radius away from the center given...
B = (mu_0*I + epsilon_0*mu_0*dE/dt*A)/r ? where r is the "radius" away from the center of the parallel plate configuration (5.00 cm)
No, that's not right. The circle on the integral sign means you have to chose a closed curve. What's the integral of B*dl around a circle?
I understand it would be 2pir for a circle, but that makes absolutely no sense with the value that they gave us because they are asking the magnetic field 5 cm from the center of the plate separation, not from the center of the actual plates themselves...and by the way, is everything else right in my equation?
You can imagine a circle 5 cm in radius encircling the center of the plate separation. The integral of B*dl would then be 2*pi*r*B while d(phi)/dt=A*dE/dt, as you said.
I submitted that and I got it wrong...when I calculated, I got 3.60 microT
I get 1.8 microT.
Ok, I figured the answer out (its not 1.80 microT or 3.60 microT because I had tried both of those before)...it is completely off base from what we were attempting to do...first of all you were on the right track with half of my answer, 1.80 microT because you didn't include the mu_0*I term from Maxwell's Equation, and just include the term with the flux (mu_0*epsilon_0*A*dE/dt)/(2*pi*r), but since dE/dt = I/(epsilon_0*A), we end up with the classic magnetic field equation (mu_0*I)/(2*pi*r), but I knew from the beginning, we had to modify that equation...the only things that didnt make sense were the "I" and "r"...
So what I did, is assume a new current through the center of the circular capacitor (and then after it passes through, it returns back to the initial current "I" from the voltage source)...so since the initial effective radius, which I'll call "r" is shrunk down into the capacitor plates' circular radius, which I'll call "R", we have (with a new current through the capacitor of " I' ")
I'/I = (pi*r^2)/(pi*R^2) --------> and therefore, I' = (r^2/R^2)I
now if we apply Ampere's law, with I', we have lineint(B*ds) = mu_0*I'
B is constant, so you can pull it out of the integral and lineint(ds) = 2*pi*r, where "r" is the radial distance away from the center of the capacitor separation. Now, since
I' =(r^2/R^2)I we have B(2*pi*r) =mu_0*(r^2/R^2)I...So therefore,
B = [tex]\left(\frac{\mu_{0}I}{2\pi R^{2}}\right)r[/tex]
= ((4pie-7)(.45)/(2*pi*(14e-2)^2))(5e-2) = 0.230 microT
  • · Replies 26 ·
  • · Replies 18 ·
