Calculating the Minimum Orbit Radius for a 'Chainworld' System
The discussion revolves around calculating the minimum orbit radius for a hypothetical 'Chainworld' system, inspired by the concept of a 'Ringworld'. Participants explore the dynamics of multiple man-made worlds orbiting a common center of mass under Newtonian physics, focusing on the gravitational and centrifugal forces at play. The conversation includes considerations of stability, configurations, and the implications of increasing the number of bodies in the system.
  • The original poster (OP) seeks to compute the minimum orbit radius for a series of cities that are held in place by gravity and acceleration, without a central star.
  • Some participants suggest that the cities are not in orbit but rather spinning, which could allow for varying speeds and tension in the system.
  • Concerns are raised about the stability of such systems, with some participants arguing that only binary systems are stable, while multi-body configurations may lead to instability.
  • There is a discussion about whether the planets in the system would rotate on their axes and how that would affect the dynamics.
  • Participants mention the Klemperer Rosette as a relevant concept, which describes a stable configuration of multiple bodies in orbit around a common center.
  • The OP expresses curiosity about the limit case of having an infinite number of bodies with the same total mass and whether this would result in a smaller orbit radius.
  • Some participants question the interpretation of the OP's request for a system without cables, suggesting that the configuration might imply some form of linkage.
Participants express differing views on the stability of multi-body systems, with some agreeing on the instability of such configurations while others explore the implications of the Klemperer Rosette. The discussion remains unresolved regarding the exact nature of the orbit radius as the number of bodies increases.
There are limitations regarding assumptions about the forces at play, the definitions of orbits versus spinning, and the implications of adding more bodies to the system. The mathematical relationships and conditions for stability are not fully explored or resolved.
HarryWertM
Trying to compute a 'Chainworld' with simplest possible Newtonian physics but still lost with my lousy math. By 'Cainworld' I mean series of man-made, worlds inspired by classic novel "Ringworld", which orbit around a common center of mass in one, common, perfectly circular orbit. They are held apart by centrifugal force and pulled together by Newtonian gravity. In 'Ringworld' , there is a star at the center of mass. I want no star, just independent 'worlds', a 'chain' of cities held in place only by gravity and acceleration.
Say you start with two cities with masses equal. Both M2. They orbit a common center of gravity with radius R. Now consider three cities with the same total mass as the first two. Do they orbit with smaller radius? What is the smallest possible orbit for unlimited number of cities with total mass equal the original total mass? Surely it has something to do with the gravitational constant, G and is some simple function of our total mass!?
They aren't in orbit.
If they are just spinning you can have them spin at whatever speed you want.
The 'gravity' felt on their surface will only depend on the diameter of the ring and the speed, the limit being the tension in the cables
As far as I remember such systems (several bodies orbiting their center of mass, all at the same distance from the center) are very unstable. Only binary systems are stable. That means that if you have stable system composed of three bodies, two of them are in relatively tight orbit (one binary system) and - as seen from the third body - they can be treated as one body, thus you have something like "higher level" binary system made of one single body and binary system. Four bodies are either "three level" binary system, of two binary systems making third one - and so on.
Yeah .. I agree with mbg. It's basically identical to setting a chain-spinning in free fall. The centripetal acceleration will cause it to assume a circumference-minimizing shape .. i.e. a circle. The effects are going to be weird though, because there will be gravity from the planets, as well as from the centripetal acceleration. Are you going to let the planets spin on their axes as well? That is, are they each going to rotate around the cable?
Also, where is the light/energy going to come from?
OP asked for no cable.
Ok .. I see what you are saying, and I guess it is the strictly correct verbatim interpretation, since the cables would indeed add a restoring force. Since he said "chain" I was assuming that the "links" were, well, linked somehow, and he meant that the configuration of the chain was determined by acceleration and gravity.
Thank you Borek, Dave & Janus! NEVER would have found 'Klemperer'.
Any ideas about my 'limit case? Near infinite number of bodies [[rocks?]] with same total
mass as original two? I figured three bodies with same total mass as first two would orbit in smaller radius than the two. So I am guessing the more 'bodies' the smaller the radius for constant total mass. Is simple function for limit radius?
You could look up some of the further reading references at the bottom of the Wiki page. One is a Java Applet simulator.
Klemperer Rosette! Damned dementia.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 23 ·
