Relay Re-Activating: Solve Problem Now | John
  • Thread starter Thread starter jbord39
    Relay
The discussion centers on a relay circuit issue where the relay disengages approximately one minute after being activated. John reports that a 100 uF capacitor charges to 6 volts and discharges to 1.83 volts when the switch is pressed. The problem likely stems from insufficient voltage or current to maintain the relay's activation, suggesting a need for circuit adjustments or component replacements to ensure stable operation.
  • Understanding of relay circuits and operation
  • Basic knowledge of capacitors and their discharge characteristics
  • Familiarity with voltage and current requirements for relay activation
  • Experience with circuit troubleshooting techniques
  • Investigate relay specifications to determine minimum activation voltage
  • Learn about capacitor discharge curves and their impact on circuit performance
  • Research methods to stabilize relay activation, such as using a larger capacitor
  • Explore circuit design principles for maintaining relay engagement
Electronics enthusiasts, hobbyists working with relay circuits, and engineers troubleshooting circuit activation issues.
jbord39
Hey guys,
I am using the following circuit to switch on/off another circuit.
The problem is that for some reason the relay will disengage about a minute after it is switched on (although it seems to remain off indefinitely).
Does anyone have any ideas for what could be causing this?
Thanks,
John
100 uF charges to 6 volt.
When switch is pressed, 100 uF discharges to 1.83 volt.
  • · Replies 31 ·
  • · Replies 26 ·
