Total angular momentum of a sphere that had both a linear v and an angular v?
The net angular momentum of a soccer ball moving with both linear and angular velocities can be calculated by combining the contributions from both motions. Given the moment of inertia of the sphere as I = (2/3)mr², where m = 0.678 kg and r = 0.142 m, the linear momentum is L = rmvsinθ, and the angular momentum is L = Iω. The total angular momentum requires vector addition of both components, taking into account the right-hand rule to determine the direction of each momentum vector.
  • Understanding of angular momentum and its vector nature
  • Familiarity with moment of inertia calculations
  • Knowledge of the right-hand rule for vector direction
  • Basic physics concepts of linear and rotational motion
  • Study the derivation of moment of inertia for various shapes, focusing on spheres
  • Learn about vector addition of angular momentum in multi-dimensional systems
  • Explore the application of the right-hand rule in different rotational scenarios
  • Investigate the effects of varying mass and radius on angular momentum
Physics students, educators, and anyone interested in understanding the principles of angular momentum in rotational dynamics.
therest
Find net angular momentum for a soccer ball (moment of inertia=2/3mr^2) that's going 3.6 m/s to the right and 28.5 radians per second clockwise at the same time.
R=0.142 m
m=0.678 kg
L=(perpendicular component of r)mv
L=Iw
L=rmvsinθ, but L also equals I*angular velocity, a rotational analog... What if both a rotational and translational velocity exist? do I add them based on these 2 equations, or what? What about the right-hand rule?
Remember that angular momentum is a vector. You need to vector add the two contributions from the rotational and translational motion of the ball. To do this, you need to know the direction of these contributions, which you determine using the various right-hand rules.
  • · Replies 17 ·
18K
