Is the speed of light constant, or could it vary with frequency?
The discussion revolves around the constancy of the speed of light in a vacuum and whether it could vary with frequency. Participants explore implications for relativity theory, the testing of Lorentz invariance, and potential scenarios from various theoretical frameworks.
  • Some participants question if the speed of light is constant in all reference frames, suggesting that this could challenge the foundations of relativity theory.
  • Others assert that the constancy of the speed of light has been extensively tested and supported by high-precision experiments, particularly regarding Lorentz invariance.
  • It is noted that the speed of light is defined as constant in all reference frames, prompting a discussion about the constancy of measurement units like the meter.
  • Some participants mention theoretical frameworks such as loop quantum gravity, which predicts a dispersive vacuum, implying that the speed of light may not be constant even in a single frame.
  • There is a proposal that the photon could have a nonvanishing rest mass, which would not necessarily violate relativity but could complicate gauge theory.
  • Participants discuss the concept of doubly-special relativity, which could introduce a higher symmetry without violating Lorentz invariance.
  • Another viewpoint suggests exploring the possibility of frequency-dependent speed of light, with references to experiments indicating very small deviations at lower frequencies and potential deviations at higher frequencies.
  • Concerns are raised about the margin of error in measurements, indicating that further study is warranted to clarify these potential deviations.
Participants express differing views on the constancy of the speed of light and its implications for relativity, with no consensus reached on whether it could vary with frequency or under different theoretical frameworks.
Some claims depend on specific theoretical assumptions and definitions, and there are unresolved questions regarding the implications of potential deviations in the speed of light.
h1a8
Is there any chance that the speed of light in a vacuum isn't constant in all reference frames, implying that Relativity theory is generally false? Do some Physicists believe that it is?
If no, why not or how can we be so sure?
Any part of physics is subject to revision if new experimental evidence comes along that requires it.
The constancy of the speed of light has been tested a lot, along with the related concept of "Lorentz invariance." So far, experiments support them with high precision. See section three of the following FAQ:
http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html
To be pedantic, the speed of light is constant in all reference frames by definition. Instead, it makes sense to ask whether the length of a meter is constant in all reference frames.
As jtbell correctly notes, the most direct way to interpret this question is to think of it as a question about the current state of the art in testing Lorentz invariance.
There are other possibilities.
Loop quantum gravity predicts that the vacuum is dispersive, so the speed of light isn't constant even in a single frame: http://arxiv.org/abs/0908.1832
The photon could turn out to have a nonvanishing rest mass:
R.S. Lakes, "Experimental limits on the photon mass and cosmic magnetic vector potential", Physical Review Letters , 1998, 80, 1826-1829, http://silver.neep.wisc.edu/~lakes/mu.html
If this is the case, then there are no implications for the foundations of relativity, but gauge theory would be in trouble.
There are other scenarios motivated by quantum gravity, e.g., doubly-special relativity: http://en.wikipedia.org/wiki/Doubly-special_relativity If doubly-special relativity is right, then there is no violation of Lorentz invariance, but there is a higher symmetry as well.
You can also search for Lorentz violation in the gravity sector rather than the photon sector: http://www.lightandmatter.com/html_books/genrel/ch02/ch02.html#Section2.4 (subsection 2.4.3)
Another possibility worth exploring is whether the speed of light is frequency dependent - varying with the frequency of the photon. In Jackson's Electrodynamics textbook he describes the experiments which have so far been done. At lower frequencies the experimental deviation is very, very small. But at very high frequencies the possible deviation is on the order of one part in a thousand. That doesn't necessarily mean there actually is a consistent deviation because the margin of error may be far greater based the measurement technique. So further study seems warranted.
A more up to date reference: http://arxiv.org/abs/0908.1832
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 74 ·
  • · Replies 33 ·
  • · Replies 45 ·
  • · Replies 53 ·
