How Does Water Affect the Angle of Diffraction for Light Through a Single Slit?
  • Thread starter Thread starter whiteman
    Diffraction Water
The discussion focuses on calculating the angle of diffraction for light passing through a single slit when immersed in water. Using the wavelength of 676 nm and a slit width of 1.60 × 10-5 m, the angle θ for the third dark fringe is determined. The correct formula for diffraction is identified as sin(θ) = m(λ)/d, rather than the incorrect m + 1/2 formulation. The final calculated angle θ is approximately 6.38 degrees.
  • Understanding of wave optics, specifically diffraction patterns.
  • Familiarity with the concept of refractive index and its application in optics.
  • Knowledge of the sine function and its application in trigonometric calculations.
  • Ability to manipulate scientific notation in calculations.
  • Study the principles of wave optics, focusing on diffraction and interference patterns.
  • Learn about the effects of different media on light propagation, specifically refractive indices.
  • Explore advanced diffraction problems involving multiple slits and varying wavelengths.
  • Investigate the applications of diffraction in optical instruments and technologies.
Students in physics, particularly those studying optics, as well as educators and anyone interested in the practical applications of wave behavior in different media.
whiteman
Light of wavelength 676 nm in vacuum is incident on a single slit whose width is 1.60 × 10-5 m. The setup is then immersed in water whose index of refraction is 1.33. What is the angle θ that locates the third dark fringe with respect to the central bright fringe?
1. sin[tex]\alpha[/tex] = (m +1/2)[tex]\lambda[/tex]/d
where [tex]\alpha[/tex] is the angle of diffraction, [tex]\lambda[/tex] is the wavelength, and d is the width of the slit
2. sin[tex]\angle[/tex]i / sin[tex]\angle[/tex]r = n
where i is the angle of incidence, r is the angle of refraction, and n is the refractive index
sin[tex]\alpha[/tex] = (3 + 1/2)(676)(10^-9)/(1.6)/(10^-5)
sin[tex]\alpha[/tex] = .147875
[tex]\alpha[/tex] = 8.5037997
sin[tex]\alpha[/tex] = sin[tex]\angle[/tex]i ( i presume, so...)
.147875/sin[tex]\angle[/tex]r = 1.33
sin[tex]\angle[/tex]r = .11118421
[tex]\angle[/tex]r = 6.383584609
i'm not sure is theta = [tex]\angle[/tex]r
i figured it out. i was using the wrong formula for diffraction. instead of m + 1/2, i should have been using m
sin(theta) = m(lambda)/(d) instead of m+1/2
