Covergence/Divergence of an Infinite Series
The discussion centers around the convergence or divergence of the infinite series \(\sum_{n=1}^{\infty}(\frac{1}{n^{1 + \frac{1}{n}}})\). Participants explore the implications of the series' structure and its relationship to known convergence tests.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the power series convergence criterion based on the exponent of \(n\). Some participants question the validity of this approach due to the variable exponent. Others suggest using the comparison test or limit comparison test as potential methods for analysis.
Participants are actively discussing various convergence tests and their applicability to the series in question. There is recognition of the challenges posed by the variable exponent, and some guidance has been offered regarding the use of the comparison test and limit comparison test.
There is an acknowledgment of the complexity introduced by the exponent depending on the summation index, which complicates the application of standard convergence tests. Participants express uncertainty about the effectiveness of the tests they are familiar with in this context.
SpringPhysics
Does the infinite series [tex]\sum_{n=1}^{\infty}(\frac{1}{n^(1 + (\frac{1}{n}))})[/tex] converge?
Power series [tex]\sum_{n=1}^{\infty}\frac{1}{n^p}[/tex]
I used the fact that for a power series, if p>1 the series will converge.
Since [tex]{n^(1+\frac{1}{n})}[/tex] will always be greater than n, the series will converge.
Is this correct? If not, can someone lead me in the right direction please?
What does [tex]\sum_{n=1}^{\infty}\frac{1}{n+1}[/tex] become when you make the substitution [itex]m=n+1[/itex] (and hence [itex]n=m-1[/itex])?
Sorry if the text isn't clear - the denominator is n^(1 + 1/n).
In that case, your argument is invalid since the exponent depends on the summation index (It's true that [itex]1+\frac{1}{n}\geq 1[/itex], but it isn't a constant value like the [itex]p[/itex] in your power series convergence test).
You will have to find another convergence test to use instead.
Sorry but do you have any in mind? The only ones I know are the comparison, ratio, and integral tests, and the function makes these tests impractical (at least I think so).
I think the comparison test is your best bet here.
I thought about that, as in the power series. Since the exponent on n is between 1 and 2, the series sits right in between a diverging (exponent 1) and a converging (exponent 2) series. Wouldn't that be inconclusive?
Sorry for the double post, but if I use the limit comparison test, letting the series {a_n} be the series of the question and {b_n} be 1/n, then the limit as n approaches infinity of a_n/b_n would = 1, but since the series {b_n} does not converge, then {a_n} does not converge as a series either. Is that it?
If the ratio exists and is non zero, then a_n and b_n converge or diverge together. You limit is 1 (non zero) so your deduction is correct.
Thank you guys so much!
  • · Replies 17 ·
