Help with a Beam Equation and Drawings
  • Thread starter Thread starter LareeRudi
    Beam
The discussion revolves around a beam problem involving point loads, where the original poster seeks assistance in creating shear and moment diagrams, as well as calculating maximum deflection. The context includes a request for help with structural analysis concepts, specifically related to beams, without the use of advanced tools.
  • Homework-related
  • The original poster, LarryR, describes a beam that is freely supported at both ends, measuring 11.00 ft in length, with specific point loads applied at various distances from the left end.
  • Some participants inquire about the type of beam (e.g., I beam, rectangular) and suggest that a sketch would be helpful for providing solutions.
  • One participant asserts that the maximum shear force is 350 lbs at the supports, based on the total load being evenly distributed across the two supports.
  • Another participant offers to share a PDF resource that explains how to create shear force and bending moment diagrams, indicating that the process is straightforward.
  • Links to external resources are provided by multiple participants, which may assist in understanding beam formulas and mechanics of materials.
  • There is a mention of the original poster's progress in understanding the concepts, as they express gratitude for the help received and indicate a transition to more complex topics like "overhung" loads.
Participants generally agree on the basic principles of shear and moment diagrams, but there is no consensus on the specific details of the beam's characteristics or the best approach to solving the problem. The discussion remains exploratory with multiple viewpoints and suggestions.
Some assumptions about the beam's material and dimensions are not explicitly stated, and the discussion does not resolve the specifics of the beam type or the exact method for diagram creation.
LareeRudi
I might be in the wrong place, let me know where to go [kindly, ha] if I am.
I havn't had math and physics etc since 1956 and never had the course "Strength of Materials"; I have a beam equation that I'd like answers to; it's not for a test, nor anything but my info, and I'd like some help drawing a Shear Diagram, a Moment Diagram, then to find the max deflection value.
If there is a more "Structural" forum that you know of, let me know. Else if I HAVE any takers here, let me know. The problem is not easy to diagram as I have no tools to DO IT. So it'll have to be all words, carefully presented.
The beam is freely supported at each end and is 11.00 ft long.
There are POINT loads [I don't want to approximate a uniformally loaded problem; I want it to be specific for these loads].
In from the left end 0.5 ft is a load of 75 lbs, in 1.5 ft is a load of 70 lbs, in 2.5 ft is 65 lbs, in 3.5 ft is 60 lbs, in 4.5 ft is 55 lbs, and in 5.5 ft [the middle] is 50 lbs, then the loading is symetrical, starting in from the right, 0.5 ft is 75 lbs, in 1.5 ft is 70 lbs, etc; total load of 700 lbs if I can still add correctly. So of course then I'd have 350 lbs on each end, but I can't get STARTED to even find the Shear forces as they increase/decrease towards the middle, then of course, same thing on creating a Bending Moment Diagram and then, a deflection equation, please.
If you can help, help me and thanks, if you've got to send me away, do it kindly, ok?
Thanks,
LarryR : )
If you could describe the beam is it an I beam? rectangular? you should sketch the details on a page and scan it and email it to me. I can then send you the solution.
I could sort this whole problem out if you give me that. I presume if its a steel s275 beam yea?
I can tell you already shear will not be a problem for an 11ft beam given that it has sufficient depth.
The max shear on this beam is on the edges where it is being supported and the value of max shear is 350lbs.
Don't laugh, but you can chuckle, ha. It's a 2 x 6, or 2 x 8 etc, so see, that is not part of the question. I'm wanting to learn how to create the shear diagram [even tho it's not going to break; I just want to know HOW to do it]. Then once the shear diagram is created, I'm wanting to learn HOW to create the Moment diagram.
So if it's a steel beam, joist, or a railroad tie, you see, I just want to know how to create those diagrams, then to find the deflection.
I'll try to figure out how to email you. And I thank you for your willingness to help.
LarryR : )
alright no problem...its not too hard to make the shear and moment diagrams i have a good pdf that i downloaded from an american university called wisconsin i think? but its really good and explains fully how to create bending moment diagrams and shear force diagrams.
i can email that to you.
to quickly demonstrate in words like yourself how easy an SFD is a horizontal line represents the beam on the very left you draw a line straight up and mark it as 350lbs...
as the max shear is on the edges and this is gotten by the (total load/2)
moving in from the left end say 2 ft in you have a 50lbs weight then from your 350 line draw a line horizontally over until you reach where the 50lbs weight acts...
Then a vertical line downwards to the value of 300lbs as the shear suffered by the beam by this weight acts down i.e. the shear values tend towards 0 as you get closer to midspan.
bending moments however are a maximum at midspan!
Essentially in this instance it will be a step like SFD...any way i dint know if I am any use at explaining but the PDF has visual aids so it should do the trick for you...just need your email.
Here are links to some reference information that might help:
http://www.awc.org/pdf/DA6-BeamFormulas.pdf
http://oak.cats.ohiou.edu/~williar4/html/HapEd/NSF/Stat/Beam.pdf
http://ocw.mit.edu/NR/rdonlyres/Materials-Science-and-Engineering/3-11Mechanics-of-MaterialsFall1999/Modules/statics.pdf
Thanks a million; that top one REALLY helped. Thanks to you and others that are emailing me, I'm beginning to get a grasp on it.... I'm graduating now to "overhung" loads, ha.
Truly, thanks.
LarryR : )
10K
