BABAR CP Violation: Explore B and Anti-B Mesons Physics
  • Context: Graduate
  • Thread starter Thread starter Olias
    Mesons
The discussion centers around the recent discovery of direct CP violation in B mesons by the BaBar experiment, exploring the implications for the Standard Model and the differences between ordinary and direct CP violation. Participants delve into theoretical explanations, experimental observations, and the nuances of particle decay processes.
  • Some participants highlight the discovery of matter-antimatter asymmetry in B mesons, noting the specific decay rates observed.
  • There is a question regarding whether the observed direct CP violation can be accounted for within the Standard Model, with suggestions that a new parameter may be needed.
  • One participant seeks clarification on the distinction between ordinary CP violation and direct CP violation, indicating a common confusion on the topic.
  • A detailed explanation is provided regarding the two modes of CP violation: indirect and direct, with examples from the neutral kaon system and the implications for decay processes.
  • Participants discuss the complexities of defining particles in terms of their CP eigenstates and the experimental feasibility of distinguishing between types of CP violation.
Participants express varying levels of understanding regarding CP violation, with some agreeing on the definitions and implications while others remain uncertain or seek further clarification. The discussion does not reach a consensus on the implications for the Standard Model.
The discussion includes complex theoretical concepts and assumptions about particle interactions that may not be fully resolved. The nuances of CP violation and its experimental verification are highlighted, but limitations in understanding and definitions are acknowledged.
Olias
SLAC said:
BaBar has now discovered direct CP violation for B mesons.
pparc.ac.uk/Nw/BABAR_CP.asp said:
By sifting through the decays of more than 200 million pairs of B and anti-B mesons, experimenters have discovered striking matter-antimatter asymmetry. "We found 910 examples of the B meson decaying to a kaon and a pion, but only 696 examples for the anti-B", explained Giorgi.
hep-ex/0407057 said:
[tex] \frac {N_{K^-\pi\+}-N_{K^+\pi^-}} {N_{K^-\pi^+}+N_{K^+\pi^-}} = <br /> -0.133 \pm 0.030 (stat) \pm 0.009 (syst)[/tex]
Is this kind of direct CP violation easily accountable for in the Standard Model ? :confused:
Maybe one will have to add a new angle for the [tex]B\bar{B}[/tex] system proper states, analogous to the Cabibbo angle ? :rolleyes:
Could someone explain the difference between ordinary CP violation and direct CP violation. I guess I am not the only one to be confused here. :rolleyes: :confused:
Two modes of possible CP violation:
1) Indirect: particles exist that are not CP eigenstates. For example, the neutral K mesons.
2) Direct: CP is violated during a decay process.
This may not be 100% clear, so let me explain. The neutral kaon system is a messy thing, because kaons are usually produced by strong interactions, in quark eigenstates, eg [itex]d\bar{s}[/itex]. But the weak interaction is not diagonal wrt quark flavors, so a higher order process can convert [itex]d\bar{s}[/itex] to [itex]s\bar{d}[/itex]. Hence the free particle states are not K and K-bar, but combinations thereof. (I know, I know. Only in QM!)
Now, you can build CP eigenstates like this:
[tex]K_1 = \frac{1}{ \sqrt{2} }(K^0 + \bar{K^0})[/tex]
[tex]K_2 = \frac{1}{ \sqrt{2} }(K^0 - \bar{K^0})[/tex]
Direct CP violation would imply that one of these states would decay to a final state that has the opposite CP number. This usually means the number of pions it decays into. This is also easy to experiment on, because an even(?) CP state decays to two
pions, and an odd(?) state to three pions. The three pion decay takes longer so one state is longer lived.
Indirect CP violation means that the particles observed in the lab are something like:
[tex]K_S = \frac{K_1 + \epsilon K_2}{ \sqrt{1 + \epsilon^2 } }[/tex]
[tex]K_L = \frac{\epsilon K_1 + K_2}{ \sqrt{1 + \epsilon^2 } }[/tex]
These states are not pure CP states. The notation means S(hort-lived) and L(ong-lived); the idea is that the long-lived particle will largely prefer a three pion decay but on occasion will go to two pions. (The mixing parameter is small, a few parts per thousand). The source of the violation is the fact that the states are mixes of the CP eigenstates - we could see further CP violation (the direct type) if the separate components were allowed to violate CP in their decays.
There are other interesting questions raised by this system. For example, what should we call a particle? The strong interaction states do not have a definite mass and lifetime, yet without a doubt they're what get produced. The L and S states do have definite masses and lifetimes. It's sort of like passing a linearly polarized photon beam through a medium that preferrentially absorbs a circular polarization; only this time the medium is the vacuum!
Anyway, I know for a fact that is possible to distinguish experimentally between the two kinds of CP violation. See http://www.slac.stanford.edu/slac/media-info/20040802/ and the links therein for a more detailed explanation; the second one from the top is most relevant.
thank you zefram_c ! It is much clearer to me now. :smile:
  • · Replies 49 ·
14K
