Expected Value and integration
The discussion focuses on calculating the expected value E(X) for a probability density function (pdf) f(Y) = 3y² over the interval [0, 1], specifically for observations falling within the range (0.5, 1). The correct approach involves integrating the pdf over the specified interval, resulting in E(X) = ∫(0.5 to 1) 3x² dx, which yields an expected value of 0.75. The confusion arises from the interpretation of the expected value in relation to the total number of observations (15), leading to the conclusion that the expected number of observations in the interval (0.5, 1) is 11.25.
  • Understanding of probability density functions (pdf)
  • Knowledge of definite integrals in calculus
  • Familiarity with expected value calculations
  • Ability to differentiate between random variables (X and Y)
  • Study the properties of probability density functions and their applications
  • Learn about definite integrals and their role in calculating expected values
  • Explore examples of expected value calculations for different distributions
  • Review common pitfalls in variable notation and integration limits
Students and professionals in statistics, data science, and mathematics who are looking to deepen their understanding of expected value calculations and probability theory.
rhyno89
Suppose that 15 observations are chosen at random for the pdf f(Y) = 3y^2 on the interval 0 to 1. Let X denote the number that lie in the interval (.5,1). Find E(X)
Ok so to get the expected value u integrate the pdf times the random variable.
Doing this is the integral 3y^3 and it turns to .75y^4
This is where I get confused. First of all I thought that it would have summed to 1 so that the number of X on that range would be 15, but it can't be it would be 11.25
Aside from that, to find the number over this range i kno is 15x the expected value but i can't figure out the bounds. Is it the value of 0,1 - the value of .5,1 or something else all together
Thanks in advance
Thanks in advance
Try to be more consistent in your use of variables. You are using x and y interchangeably, and that's bound to lead to confusion.
[tex]E(x) = \int_{0.5}^1 3x^2 dx[/tex]
You got the right antiderivative, but you should be working with a definite integral. Since you're concerned only with the interval [0.5, 1], you should expect the expected value to be a number somewhere in that interval.
