First Law of Thermodynamics and automobile
The forum discussion centers on the application of the First Law of Thermodynamics to an automobile battery's charging and discharging processes. The battery discharges 1000 kJ of heat to the environment while sitting idle, and requires 440 Wh (1584 kJ) of work input to recharge. The thermodynamic analysis reveals that during the charging process, the heat interaction of the battery is calculated to be -584 kJ, contradicting the book's answer of +440 kJ. The participants conclude that the book's answer is incorrect based on their calculations.
  • Understanding of the First Law of Thermodynamics
  • Knowledge of energy units (kJ and Wh)
  • Familiarity with thermodynamic processes (charging and discharging)
  • Ability to perform energy balance calculations
  • Study the First Law of Thermodynamics in detail
  • Learn about energy conversion and efficiency in battery systems
  • Research thermodynamic cycles and their applications in automotive engineering
  • Explore the implications of heat transfer in electrochemical systems
Students studying thermodynamics, automotive engineers, and anyone interested in the energy dynamics of battery systems.
Gil-H
An automobile battery that is originally fully charged gradually discharges while sitting on a shelf at a constant temperature of 40C, producing no electric work but resulting in a heat transfer of 1000kJ to its environment.
The battery is then recharged to its initial state by means of a process involving work input of 440Wh.
Find the heat interaction of the battery during this charging process. Justify your answer thermodynamically.
The first law of thermodynamics
ΔE = Q -W
in the first step, heat is moving out of the system and no work is done, so:
Q12 = -1000kJ
W12 = 0
in the charging process, the is done on the system, so:
W21 = -440Wh = -440[Wh]*3.6[kJ/Wh] = -1584kJ
The battery is charged to its initial state, so:
ΔE = 0
ΔE12 + ΔE21 = 0
(Q12 - W12) + (Q21 - W21) = 0
-1000kJ + Q21 +1584kJ = 0
and
Q21 = -584kJ
the answer in the book is +440kJ. Why? What have I done wrong?
I am not sure what is meant by "heat interaction" of the battery.
If the battery in its initial state can supply 1000KJ of energy to its environment by discharging, and if 1584KJ (440Wh) of work is needed to recharge it to its original state (original charge and temperature), then the battery must dissipate 584KJ of heat to the environment in the charging process. [itex]\Delta Q = \Delta U + W = 1000KJ - 1584KJ = -584KJ[/itex] (W = +work done BY the battery)
I would say the answer given is wrong and you are correct.
AM
  • · Replies 46 ·
