Thread Closed
reversing order of integration of double integral qns.
Share Thread Thread Tools
Mar22-10, 01:02 AM   #1
pls refer to attached picture.
2. Relevant equations
3. The attempt at a solution
intially upper and lower limits are , x^2 < y< x^3 and -1<x<1
sketched y=x^2 and y= x^3. => sqrt(y) =x and cube root (y) = x
divide the area into 3 section.
new limits of dxdy
sqrt(y) <x< cube root (y) with 0<y<1 ,
and 0<x< sqrt(y) with 0<y< -1, ( for -ve x and +ve y portion of x^2 graph)
and cube root (y)< x< 0 with -1<y<0 ( for -ve x and -ve y portion of x^3 graph)
but the answer i have shows a different answer. guess i am wrong, but anyone can tell me which part?
attached is a graph i tried to draw( pardon my IT skills=P)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar22-10, 12:05 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Your picture is good, but you should emphasize that the region is also bounded by a vertical segment at x=(-1). Doesn't that mean some of your lower limits in the x integration need to be -1?
Mar22-10, 12:17 PM   #3
hmm..to find limit of x integration we draw vertical line? so when i split the area to three sections, their upper limits is cube root y or sqrt y and the lower limit is 0?
yea, but according to the answer i have, it uses limits of x integration as -1..and i dont understand why?
could you kindly explain to me?
Mar22-10, 12:26 PM   #4
Recognitions:
Take your diagram and draw a segment connecting (-1,1) and (-1,-1). That's the boundary curve that determines your lower limit when you are doing the x<0 parts of the integration.
Mar22-10, 12:48 PM   #5
opps..i was wrong, we should draw horizontal lines instead. and yup..
i get jus (for the -ve x portion)
-1 < x < sqrt y with 0< y< 1
and -1 < x < -x^3 with -1< y < 0
using the these lines as a guide..
Mar22-10, 12:50 PM   #6
opps i only can attach files when i post a thread? cant seem to be able to upload the edited graph here??
Mar22-10, 01:36 PM   #7
Recognitions:
Quote by blursotong View Post
You'll need to express x limits in terms of y. And for both of them, the upper limit should be a negative number, like your graph shows.
Mar22-10, 07:53 PM   #8
yup.i got them now.
i get (jus for the -ve x portion)
-1 < x < -sqrt y with 0< y< 1
and -1 < x < -cube root y with -1< y < 0
thanks alot for your guidance=D
Mar22-10, 09:12 PM   #9
Recognitions:
yup.i got them now.
Are you super sure about that -cube root(y)?? Remember if y is negative then cube root(y) is already negative.
Mar23-10, 08:32 AM   #10
ahah! my wrong..it should be jus cube root of y...
thx for pointing out!!
=D
Thread Closed
Thread Tools
Similar Threads for: reversing order of integration of double integral qns.
Thread Forum Replies
choosing the order of integration with double integration Calculus & Beyond Homework 3
Reversing the order of integration Calculus 5
Reversing Double Integral Calculus & Beyond Homework 6
Evaluating Double Integrals: Switching the Order of Integration Calculus & Beyond Homework 5
