Unique Arrangements of n As and Bs in a Circle | Combinatorics Homework
  • Thread starter Thread starter simpleton
    Combinatorics
The problem involves arranging n identical As and n identical Bs in a circular formation, seeking to determine the number of unique arrangements. This falls under the subject area of combinatorics.
  • Participants discuss initial attempts to calculate arrangements linearly and then adapt those results to a circular context. There is exploration of patterns in the results for small values of n, and questions about the validity of proposed formulas are raised.
The discussion is ongoing, with participants sharing their calculations and questioning the assumptions behind the proposed formulas. Some guidance has been offered regarding the complexity of counting arrangements due to cyclic permutations, and alternative approaches have been suggested.
Participants note that the problem's complexity increases with the need to account for cyclic permutations and periodic configurations, which complicates the straightforward application of combinatorial formulas.
simpleton
You are given n identical As and n identical Bs. You are supposed to arrange them in a circle. How many unique arrangements are there?
Use of combinatorics
At first, I tried working out the answer if I arrange them in a row. The answer is (2*n)!/(n!*n!). Then I tried to multiply something to this to get the answer. However, I cannot find a way to do so. For example, I tried dividing it by 2*n, but this does not work, because not all the arrangements repeated 2*n times.
I worked out some answers below in case someone needs them.
for n = 1, there is only 1 way {AB}
for n = 2, there are 2 ways {AABB, ABAB}
for n = 3, there are 4 ways. {ABABAB, AABBAB, AABABB, AAABBB}
for n = 4, there are 9 ways if I did not count wrongly {AAAABBBB, AAABBBAB, AAABBABB, AAABABBB, AABAABBB, AABBAABB, AABABABB, AABABBAB, AABBABAB}
Sorry, my combinatorics is not that good. This is all I can do :(
You missed one in the n=4 case, namely ABABABAB.
You should be able to see a pattern between the results of your formula and the actual numbers for these four cases.
Oh right, I missed that case
So let f(n) be the answer
f(1) = 1
f(2) = 2
f(3) = 4
f(4) = 10
Hmm, is the answer (2n)!/(n!*n!*(2*n-1))?
If that is the answer, can I know how to prove that?
Thanks.
If you're dividing by 2n-1, that means each pattern repeats 2n-1 times. Why would each pattern repeat that many times?
I have no idea actually :(. It just seems that it fits the pattern, so I thought that is the answer.
Sorry, I am not too sure how to do these kinds of combinatorics problems :S
No need to be sorry. This problem is more complicated than I thought, too. The formula doesn't work for n=1. It seems the counting is complicated because the some of the n!n! permutations are the same as cyclic permutations. For example, from abAB, you can get ABab by swapping 1, 3 and 2, 4, or by shifting by 2.
This is why Polya invented his theorem.
Although with only A and B, the problem is rather simple as you can only have one type of pattern that maps onto itself under rotations.
You can try this approach. You an try to account for all the (2n)!/n!^2 configurations when the A's and B's are arranged in a row, using the configurations on the circle in which two related by rotations are identified.
Most configurations on the circle give rise to 2n configurations when rotated in all possible ways. The exceptions are the periodic ABABABABABA.. ,AABBAABBAA, AAABBBAAABBB, etc. configuration. These configurations give rise to k row configurations, where k is the length of the period.
And then note that finding the number of periodic configurations amounts to solving the same problem but now with 2n replaced by the period.
So, this suggest an approach involving inclusion/exclusion or Möbius inversion.
16K
  • · Replies 16 ·
  • · Replies 29 ·
