When is it appropriate to use a time dependent Schrodinger's wave equation?
  • Context: Graduate
  • Thread starter Thread starter roshan2004
    Wave Wave equation
The discussion revolves around the conditions under which the time-dependent and time-independent Schrödinger wave equations are appropriately used. Participants explore theoretical aspects, applications, and preferences in solving quantum mechanical problems involving different types of potentials.
  • Some participants assert that the time-independent Schrödinger equation (TISE) is applicable only for stationary states.
  • Others argue that the time-dependent Schrödinger equation (TDSE) is always the right choice, particularly when dealing with time-dependent potentials.
  • A participant suggests that if the potential is time-independent, one can use a trial solution to derive the TISE from the TDSE.
  • Another viewpoint emphasizes that the choice between TDSE and TISE depends on whether the potential is time-dependent or not, and that TISE may be preferable for time-independent potentials.
  • Some participants express that using TISE first can simplify finding energy eigenstates, which can then be used to construct time-dependent wavefunctions.
  • There is mention of using perturbation theory when treating time-variant potentials as weak perturbations.
  • One participant proposes that for strongly-coupled time-dependent potentials, neither form of the Schrödinger equation may be suitable, suggesting the use of the interaction picture instead.
  • Another participant emphasizes that there is fundamentally one equation that describes the physics, and that the others are special cases, aiming to clarify misconceptions about dualities in physics.
  • Some participants discuss the relevance of time in determining probabilities and energy measurements, noting that the TISE provides the energy eigenvalues while the TDSE governs the time evolution of state functions.
Participants express differing opinions on the appropriateness of using the TDSE versus the TISE, indicating that multiple competing views remain. There is no consensus on which approach is universally preferable, as preferences seem to depend on the specific context and nature of the potential involved.
Participants highlight the importance of the potential's dependence on time and position in determining the appropriate equation to use. There are references to perturbation theory and the interaction picture, suggesting that the discussion is nuanced and context-dependent.
roshan2004
In what conditions do we use time dependent and time independent Schrödinger's wave equations?
The time independent Schrödinger's wave equation is used only for a stationary state.
The time-dependent version is always the right choice.
However if your potential does not depend on time, but position only [itex]V(x)[/itex] (unlike [itex]V(x,t)[/itex]), then you can use the trial solution [itex]\psi(x,t)=\phi(x)e^{-i E t/\hbar}[/itex] and derive an equation for the special part [itex]\phi[/itex] of the wavefunction. You effectively get the time-independent version of the Schrödinger equation. From this time-indepedent special case you can first find [itex]\phi[/itex] and E and finally put it back into the full wavefunction [itex]\psi(x,t)[/itex]. Please try that above exercise with the trial solution.
I don't agree. It makes sense to use the time-dependent Schrödinger equation (TDSE) when solving a problem for a time-dependent potential. However quite often what one is most interested in is the energy spectrum and/or eigenstates of a time-independent potential. In such a case, it is preferable to solve the time-independent Schrödinger equation (TISE), either analytically (this is only rarely possible for meaningful real-world problems), or numerically (i.e. using the variational method and diagonalizing a large matrix).
Once the eigenstates are known, one then gets the time-dependent wavefunctions for free, since the time-dependent part of the wavefunction for the jth eigenstate is just:
[tex]f_j(t)=e^{-i\frac{E_j}{\hbar}t}[/tex]
where Ej is just the jth eigenvalue. In fact, any time dependent wavefunction can be written as a linear combination of these solutions, since they form a complete basis.
I guess it is largely a matter of taste, but I find the latter approach simpler to understand and use.
It's not a matter of taste. What you want to use merely depends on whether your potential is [itex]V(x,t)[/itex] or [itex]V(x)[/tex]. What time-independent eigenstates do you want to find if you haven't even given a time-independent potential to deal with?<br /> <br /> Maybe you are referring to some perturbation theory approximations?[/itex]
[itex] <br /> Read my first sentence again .. you said it is *always* best to use the TDSE. I said it is best to use the TISE when solving a time independent potential. <br /> <br /> To answer your question, yes, I would also tend to use the TISE first in cases where it is appropriate to treat the time-variant part of the potential as a (weak) perturbation.<br /> <br /> In cases where there is truly a strongly-coupled time-dependent potential to deal with, I would probably not use either form of the Schrödinger equation, but instead I would formulate solutions in the interaction picture, where quantum propagators are used to describe the time-evolution of some initial state, which I would represent as a linear combination of eigenstates. Of course that choice is largely due to my own education and training, and the sorts of problems I run into in my research. Honestly, outside of fairly straightforward derivations and pedagogic illustrations, I have found little use for the TDSE.<br /> <br /> I understand that others will have a different take .. I was just providing a counter-example to your statement that, "The time-dependent version is always the right choice."[/itex]
I wanted to emphasize that there is only one equation that describes the physics. Everything else is a special case. This is to prevent misconceptions about "dualities" and "special cases".
I had the impression the author of the initial question was thinking there are two different equations and you have to make a lucky guess which one to use. I prefer to teach that there are no dualities, i.e. conflicting definitions in physics. Absolutely everything in physics can be transformed consistently into each other.
You are right. I didn't mean to say that you should actually chose the most general equation to handle all problems.
If you are interested in a) the possible results of an energy measurement and b) the probability distribution of those results, then you must solve the energy eigenvalue equation where the energy operator is the Hamiltonian [tex]\hat H = - {{\hbar ^2 } \over {2m}}{{\partial ^2 } \over {\partial x^2 }} + V(x)[/tex] in one dimension for a time independent potential. This energy eigenvalue equation is what we call the time independent Schrödinger equation.
The solution gives us the energy eigenvalues [tex]E_n[/tex], which are the only possible results of an energy measurement. The state function, [tex]\psi (x)[/tex], determined by the state preparation procedure, must then be written in the energy representation where the basis functions [tex]\left| {E_n } \right\rangle[/tex] are the eigenfunctions of the Hamiltonian. Now [tex]\left| {\left\langle {{E_n }}<br /> \mathrel{\left | {\vphantom {{E_n } \psi }}<br /> \right. \kern-\nulldelimiterspace}<br /> {\psi } \right\rangle } \right|^2[/tex] gives us the probability of getting the energy value [tex]E_n[/tex] when we know the system is in state [tex]\psi (x)[/tex]. Note that time is not a relevant parameter here.
However, all state functions will vary in time according to the time dependent Schrödinger equation [tex]i\hbar {{\partial \psi (x,t)} \over {\partial t}} = \hat H\psi (x,t)[/tex]. The probabilities might change with time, depending on the situation.
  • · Replies 39 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 17 ·
