What is the initial speed of a bullet shot into a block on a frictionless table?
  • Thread starter Thread starter oadeyemi
    Block Bullet
The problem involves a bullet of mass m being fired into a block of mass M that is initially at rest on a frictionless table. After the bullet embeds itself in the block, the combined system falls and lands a distance d from the table. The objective is to determine the initial speed of the bullet.
  • Participants discuss the application of energy conservation principles and the equations related to inelastic collisions. There is a focus on the relationship between potential energy and kinetic energy, as well as the implications of the collision type.
Some participants express uncertainty about the correctness of the derived formulas and the interpretation of the variables involved. There is an ongoing exploration of the relationship between vertical and horizontal components of motion, with suggestions to clarify the distinction between them.
Participants reference external resources, such as a Wikipedia article on inelastic collisions, to address potential misunderstandings. There is a noted concern about the initial conditions of the block and the implications for the calculations being performed.
oadeyemi
A bullet of mass m is fired into a block of mass M initially at rest on a frictionless table of height h. The bullet remains m in the block, and after impact the block lands a distance d from the bottom of the table. Determine the initial speed of the bullet.
I used (m +M)gh for the potential energy and set that equal to the kinetic energy ½(m + M)v₂² and found that v₂ = √(2gh).
And since it was a completely inelastic collision (right?) I used mv₁ = (m + M)v₂ → v₁ = (m + M)v₂ * 1/m
Is this right?
initial velocity = √(2gh)*((m + M)/m)
Do you have an attempt at the problem? If not, tell me your thought process for the problem.
Is this right?
Something about this chunk doesn't seem right to me for some reason. Everything else is correct, from my understanding. Is this a formula you received from your text, or is this something that you derived yourself?
Check out the Wiki article, I think I see where you're going with this, but I see a slight error in your formula: http://en.wikipedia.org/wiki/Inelastic_collision
It's from my textbook
I think the formula here is OK, wiki describes different situation (initial velocity of M not being zero) and uses different symbols, hence the confusion.
Problems are with the other part - v2 that you calculated from the energy conservation is a vertical component of the speed when block with a bullet hits the ground. That's not initial HORIZONTAL speed of the body.
Elaborate please
Once the bodies (m+M) left the table they behave just like something thrown norizontally - they maintain horizontal speed, but they start to fall down, till they hit the ground at distance d from the table border.
  • · Replies 31 ·
15K
