Do Gravitons Play a Role in Simulated Gravity on a Rotating Spacestation?
  • Context: Graduate
  • Thread starter Thread starter Glenn
    Gravitons Gravity
The discussion revolves around the role of gravitons in the context of a rotating spacestation simulating Earth-like gravity (1g). Participants explore the implications of the equivalence principle and the geometry of spacetime, while also referencing analogies such as the rubber sheet model. The conversation touches on both classical and quantum perspectives of gravity.
  • Glenn questions whether gravitons are involved in simulating gravity on a rotating spacestation and how the equivalence principle applies.
  • One participant suggests that gravitons are not necessary for describing a rotating spacestation, emphasizing the use of classical general relativity (GR) and the geometry of spacetime instead.
  • Another participant notes that the rubber sheet analogy can be misleading and highlights the frame-dependent nature of gravitational fields.
  • There is a mention of the equivalence principle, which states that acceleration and gravity cannot be distinguished, suggesting that gravity can be simulated through acceleration.
  • A later reply emphasizes the distinction between quantum gravity and general relativity, arguing that they represent fundamentally different approaches to understanding gravity.
  • Some participants propose using Lagrangian mechanics to explain the forces experienced by an observer on the spacestation, while acknowledging the complexity involved in this approach.
Participants express differing views on the necessity of gravitons in the context of the spacestation and the interpretation of gravitational effects. There is no consensus on the best approach to explain the phenomena, with multiple competing perspectives presented.
The discussion reveals limitations in understanding the interplay between quantum mechanics and general relativity, as well as the challenges in applying classical concepts to non-inertial frames. Some assumptions about the nature of gravity and spacetime geometry remain unresolved.
Glenn
If a spacestation were rotating to simulate 1g Earth conditions, would gravitons be involved? Is this a gravity well like the rubber sheet analogy. How does the equivalence principle play into all this.
Please keep the answer in laymans terms if at all possible. I want some hopes of understanding it ;-)
-Thanks,
Glenn
You only really need gravitions if you're trying to quantize gravity. You don't need quantum gravity to describe a rotating spacestation, so it's best not to even think about gravitions, especially since we don't even have a theory of quantum gravity yet.
You could start talking about the geometry of space-time for a rotating space-station using classical GR. The geometry is non-euclidean, this shows up in many ways, one of them being that light beams don't travel in straight lines in the rotating reference frame. This would be significantly more produtive than talking about gravitions, and rather interesting if one has the right background. However, it's far from the simplest approach. Only a very few people are going to be interested or able to follow the classical GR approach.
The simplest answer is to use standard Newtonian physics, and to point out that the observer on the space-station needs to accelerate constantly to maintain his posiition, and that this centripetal acceleration gives the space-station dweller the illusion of gravity, just like he was in an linearly accelerating rocketship.
A slightly more sophisticated answer is to use Lagrangian mechanics, so that one can talk about generalized forces. The use of generalized forces allows one to talk about the apparent "centrifugal" and "coriolis" forces that the space station dweller experiences. This requires more advanced physics, but I think it actually gets closer to what the space-station dweller experiences. The only problem with this is that someone will probably pipe up and say that "centrifugal force isn't a force", and explaining the nature of a generalized forces rigorously requires a lot of math, though it's fairly easy to grasp an intuitive concept of it.
That would be my guess.
The rubber sheet analogy can be misleading. It can give you an idea of what the geometry of the spacetime is but it wouldn't, for example, be useful in describing a uniform gravitational field since that is a frame dependent notion. The equivalence principle comes in by being able to describe the objects as moving on this "rubber sheet".
The geometry of spactime does not change when you change from an inertial frame of referance in flat spacetime to a rotating frame of reference.
Pete
-Thanks,
Glenn
you can't mix the two up. Gravity in quantum mechanics and in general relativity are two different things. IF one if found out to be true, the other one will be ultimetelly false. You can't have both. One theory (quantum theory) talks about a vitrual particle interaction between matter particles. This virtual particle is called a graviton. On the other hand, general relativity talks about bending of space time, and this is the cause of gravity. This is not an analogy, by the looks of theories today and experimental results, this is a true effect that takes place. We will actually be given more insight in about a month, when Gravity Probe B experiments begin being examined.
About your question with the equivalence principle, this is nothing hard to understand. All Einstein said was that there cannot be a gistinguishable factor between acceleration and gravity. Gravity in a sense can be simulated with acceleration and you can't tell the difference between the two.
  • · Replies 33 ·
  • · Replies 20 ·
  • Poll Poll
  • · Replies 40 ·
13K
  • · Replies 21 ·
  • · Replies 76 ·
12K
  • · Replies 18 ·
