Thread Closed
Parallel plate capacitors
Share Thread Thread Tools
Mar23-10, 11:23 PM   #1
The area of the plates of a parallel plate capacitor is 1 m2, the spacing between the plates is 10 cm, the potential difference between the plates is 1500 V. After beign charged, the plates are disonnected electrically from the surroundings. The plates are then pulled farther apart so that the new spacing is 11 cm.
a. What is now the potential difference between the plates?
b. How much work is required to pull the plates apart?
c. Assume that the pulling apart of the plates is accomplished by a constant force of 10 N more than the force required to keep the plates apart. How fast are the plates moving away from one another when the plates are separated by 11 cm?
2. Relevant equations
W=F*dr
3. The attempt at a solution
The first parts are doable, if, like I'm assuming, the charge is going to be constant. However, without a mass given, I can't see how part c is going to work out. I figured it'd have something to do with energy conservation or kinematics, but I don't know how to solve for v without an m to put into the energy equation, or to figure the acceleration. Any help is appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Mar24-10, 01:13 AM   #2
Recognitions:
Homework Helper Homework Help
You're right. You need the mass of the plates to answer the question.
Thread Closed
Tags
capacitor, electrostatic
Thread Tools
Similar Threads for: Parallel plate capacitors
Thread Forum Replies
parallel plate capacitors Introductory Physics Homework 5
parallel plate capacitors..please help! Introductory Physics Homework 1
Parallel Plate Capacitors- Please Help Introductory Physics Homework 1
HELP! Parallel plate Capacitors... Introductory Physics Homework 7
Parallel Plate Capacitors Introductory Physics Homework 2
