Non-destructive testing - Porosity
  • Thread starter Thread starter Marbig
    porosity Testing
The discussion centers on non-destructive testing (NDT) methods for assessing porosity in a bearing pad that failed a porosity test. Key testing methods mentioned include penetrant testing, radiography, eddy current testing, and helium/gas pycnometry. The participants emphasize that penetrant testing is suitable for surface or open porosity, while radiography can identify voids but requires calibration with known standards. The conversation concludes with a recommendation to explore various NDT methods for accurate assessment and repair decisions.
  • Understanding of non-destructive testing (NDT) principles
  • Familiarity with penetrant testing techniques
  • Knowledge of radiography and its calibration requirements
  • Basic concepts of eddy current testing and its applications
  • Research helium/gas pycnometry for porosity measurement
  • Learn about the calibration standards for radiography in NDT
  • Explore the limitations and applications of eddy current testing
  • Investigate ultrasonic testing (UT) methods for porosity detection
Engineers, quality control specialists, and technicians involved in material testing and repair processes, particularly those focused on non-destructive testing methods for assessing porosity in industrial components.
Marbig
Hi all,
We have a bearing pad at work that failed a porosity test and could not hold pressure (this was the pad itself and not the babbit surface).
I need to look into some NDT testing that will give us an idea about the porosity. I have googled and some sites say different things, from what I gather it will be penetrate testing, radiography or eddy current.
Basically I need a test that will allow me to say to someone that this pad needs to be repaired so that "XXX test" reveals that surface defects are less than "xxx (some sort of classification that corresponds to the test method)" so that it will past its porosity test.
This will be more specific than simply saying that the pad needs to be repaired so that the porosity test will be passed.
I would be interested in hearing your opinions. Thanks for all your help.
Penetrant testing only works for surface or open porosity, i.e. porosity connected to the surface.
Radiography might work depending on the type of porosity. Radiography usually looks for voids, but density (1 - porosity) would require calibration (with standards of know porosity/density).
Eddy-current may not work - it is usually used for surface flaws (voids) - and it also would require calibration.
Depending on the size, helium/gas pycnometry might work.
UT might also work.
Look here for some ideas.
http://www.ndt-ed.org/GeneralResources/MethodSummary/MethodSummary.htm
  • · Replies 28 ·
