Theoretical and actual limits to electromagnetic frequencies?
The discussion revolves around the theoretical and actual limits of electromagnetic frequencies in the universe, exploring both upper and lower bounds. Participants consider implications from quantum mechanics, the Heisenberg uncertainty principle, and the nature of electromagnetic radiation across different contexts, including theoretical constructs and practical observations.
  • Some participants propose that the theoretical upper limit for electromagnetic frequencies could be related to Planck time, while others suggest that there is no known theoretical upper limit.
  • It is mentioned that practical upper limits for electromagnetic waves are often around 1 MeV (2.4 x 1020 Hz), due to pair production constraints.
  • Some participants discuss the highest-energy photons detected, which can reach tens or hundreds of MeV, and the role of virtual photons in particle colliders.
  • For lower limits, there are references to very long radio waves generated from antennas, with wavelengths potentially reaching hundreds of kilometers.
  • Some participants speculate that if the universe wraps back on itself, a long-wavelength cutoff could occur based on the maximum distance around the universe.
  • There is a discussion about the feasibility of generating extremely long electromagnetic waves, with some suggesting that such waves could have originated in the early universe and grown through redshifting.
Participants express multiple competing views regarding the theoretical and practical limits of electromagnetic frequencies, and the discussion remains unresolved with no consensus reached on specific bounds.
Limitations include the dependence on definitions of frequency and energy, as well as unresolved mathematical steps regarding the implications of quantum mechanics and cosmological considerations.
inhahe
i'd like to know two things
a) is there a theoretical upper and/or lower bound to electromagnetic frequencies in the universe? I'm thinking for an upper limit, 1/planck time?
for a lower limit, i have no idea-- does Heisenberg uncertainty calculate into that? i suppose it would when you consider the limited size of the universe, if the frequency is so tiny that only a part of the wave exists spans the universe at one time..?
b) what are the *actual* detected or even speculated upper and lower limits for electromagnetic waves? i know there are various graphs on the internets depicting the spectrum between AM radio and gamma rays, but the upper limits range from 10^20 hertz to 10^23 hertz, and the lower limits range from 10^3 hertz to 10^6 hertz depending on the graph. and they don't give numbers with any more precision than the order of magnitude.
thanks..
Space news on Phys.org
The practical upper limit on electromagnetic waves is often around 1MeV (2.4 * 10^20Hz). This is because above this energy, the EM wave has enough energy for pair production (electrons have a mass of about 0.5 MeV). EM waves above this energy tend to decay very rapidly due to this process.
However, there is no known theoretical upper limit. When computing interactions in quantum electrodynamics, we do have to select some upper limit on photon energies, but our calculations are independent of the choice of upper limit, and we have as yet no evidence to indicate where it may be.
thanks..
Well, the highest-energy photons that we directly detect (and are sure are photons) are products of nuclear reactions, which can go up to tens or even hundreds of MeV. Higher-energy still are virtual photons produced in particle colliders that may have energies with hundreds of GeV (so far), but almost instantaneously produce other particles. The problem is, the physics work out so that at the current time, all our calculations are independent of the photon cutoff, so we just have no evidence pointing to where that might be as yet.
For the lower limit, i guess that must be very “long” radio waves (whose wavelength can reach hundreds of kilometers). That is for EM radiation generated from an antenna.
For EM radiation generated from atomic emission, that might be the transition from 2p1/2 -> 2s1/2 in the hydrogen atom (those levels are only separated by the Lamb shift)
Photons can't decay; if there's a high density of photons above ~0.5 MeV, you can produce electron-positron pairs in photon-photon collisions.
In interstellar space, photons with much higher energies can travel freely. http://en.wikipedia.org/wiki/Fermi_Gamma-ray_Space_Telescope" routinely detects photons far in the GeV range. Pair production with the CMB should be an issue for Energies > 10^14 eV, if I made no math error. Ordinary background light (from stars and such) is more important there, IIRC.
If our universe wraps back on itself, a long-wavelength cutoff would be caused by the maximum distance around the universe before wrapping back on itself (this would be at least a few times the ~50 billion light years size of the observable universe).
OK but what would generate such an EM wave ?! :biggrin: Can you imagine the size of the antenna ? :eek:
Well, it's actually impossible to physically generate a wave that large now, just due to causality reasons. But such a wave that was produced in the very early universe might well have grown to that size through redshifting. It's obscenely unlikely to have survived through the hot early period of our universe, but it's not fundamentally impossible.
  • · Replies 0 ·
  • · Replies 29 ·
