Thread Closed
Please Help! Finding kilowatt hours from parallel capacitors
Share Thread Thread Tools
Mar24-10, 03:30 PM   #1
A parallel-connected bank of 5.00 µF capacitors is used to store electric energy. What does it cost to charge the 2900 capacitors of the bank to 45,000 V, assuming a unit cost of $0.03 per kW·h?
2. Relevant equations
CV = Q
1 Joule = 2.77E-7 kWh
1 Volt = 1 Joule per Coulomb
3. The attempt at a solution
I'm not sure how to convert from Volts to Joules and then to kilowatt hours. I tried CV=Q to find the Coulombs, from where I wanted to find the number of Joules. If my thinking is correct, the 45,000 Volts means there are 45,000 Joules per Coulomb. When i multiplied 5E-6 times 45,000 to find Q my result was that the charge was only .225 C for one capacitor, which seems low. I'm not sure where to go from here, and I'm very unsure of how to convert from Volts to Joules to Kilowatt hours. I know at the end I need to remember to multiply my final result by 2900 for the number of capacitors. I also don't know how the fact they're connected by parallel plays into this.
Please help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar24-10, 03:40 PM   #2
Recognitions:
Homework Helper Homework Help
Are you familiar with the formula E=1/2CV^2 or E=Q^2/2C? Those are the formulas for the energy stored in a capacitor.
Mar24-10, 03:55 PM   #3
Okay, i'll try that and see if i can work out the right answer
Mar24-10, 04:18 PM   #4
The units for E is in joules correct?
Mar24-10, 05:23 PM   #5
Recognitions:
That depends on what you use for C, V, and Q. If you use standard SI units, E will come out in joules.
Thread Closed
Tags
capacitors, cost, electricity, kilowatts, parallel
Thread Tools
Similar Threads for: Please Help! Finding kilowatt hours from parallel capacitors
Thread Forum Replies
Horsepower to kilowatt-hours? Introductory Physics Homework 16
Something about parallel capacitors Classical Physics 8
Parallel capacitors Introductory Physics Homework 7
2 Capacitors in Parallel Introductory Physics Homework 4
Ok im mad confused about generators and kilowatt/kw hours.... Electrical Engineering 23
