Quantum Physics: Probability density
The discussion revolves around evaluating the probability density and radial probability density for the ground state of the hydrogen atom, specifically at the points r = 0 and r = rb. Participants are exploring the application of probability functions in quantum physics.
  • Participants discuss the evaluation of the wavefunction and its implications for probability density. There is confusion regarding the correct variables and functions to use, particularly in relation to the hydrogen atom versus other contexts, such as a particle in a box. Questions arise about the evaluation process and the significance of the results at specific points.
Some participants have provided guidance on the definitions of probability density and radial probability density, while others are questioning their understanding of the variables involved. There is an acknowledgment of differing interpretations and approaches to the problem, with no explicit consensus reached.
Participants are navigating potential misunderstandings about units and the application of formulas, particularly regarding the expected size of answers and the context of the problem. There is mention of imposed homework rules that may limit the information available to participants.
frankR
For the ground state of the hydrogen atom, evaluate the probability density psi^2(r) and the radial probability density of P(r) for the positions.
a) r = 0
b) r = rb
I confused how this probability function is used. What's the technique here?
Thanks
In this problem, you are only being asked to evaluate functions of a single variable variable at two different points. It's no different than if you were asked to evaluate f(x) and g(x) at x1 and x2 in Algebra II, for instance.
The wavefunction Ψ(r) should be in your book. You already stated the definition of the probability density (|Ψ|2), and the definition of the radial probability density is bound to be in your book, too. Compute those functions, and then insert r=0 and r=rb (the Bohr radius). No integration is required.
Okay, what do I use for A, n, L and x?
If I evaluate x=0 I get 0. But the answer is non-zero.
Whoa: What are A, n, and L? Also, don't you mean r instead of x?
If you evaluate what at r=0? The probability density is nonzero there, but the radial probability density is zero.
Halliday gives:
|Ψ|2(x) = A2Sin2(n[pi]/L * x), n = 1, 2, 3,...
No radial coordinate.
Halliday gives:
(|Ψ|2) = A2Sin2(n:pi:/L * x), n = 1, 2, 3,...
That's the wavefunction for a particle in a box. It isn't applicable to the hydrogen atom. You need to look up that wavefunction, which will certainly have a radial coordinate.
So I want this:
Ψ(r) = 1/(sqrt[[pi]a3/2) e-r/a
Square that and evaulate, or can I just evaluate and squre?
Yes, that's the one. It makes no difference what order you do the evaluating and squaring in. Don't forget that you also have to do it for the radial probability density.
For some reason the answer I'm getting is no where close to the given answer: 2150(nm)-3
I get: 6.121e^9
And you got your answer how...?
I just plugged it into my calculator.
Since a=5.29x10^-11m the answer should be very large.
This must not be the correct formula or something.
You should ask yourself:
It should be very large in what units[/color]?
You are working in meters, and the answer was given in inverse cubic nanometers[/color].
HAHHAHA!
That's what happens when you do physics for 10 hours straight.
Edit: BTW, I've never seen that type of unit used before so my brain must have dismissed it.:smile:
Oh BTW: Thanks for your help Tom.
  • · Replies 16 ·
