Magnitude/direction of the ball's acceleration
  • Thread starter Thread starter 14h54
    Acceleration
The discussion focuses on calculating the speed, magnitude, and direction of a 2.0 kg ball swinging in a vertical circle with an 80 cm string at an angle of 30 degrees. The tension in the string is 20 N, leading to the calculation of the ball's speed as 3.8 m/s using the formula v=sqrt((T - mgcos(theta)) * r). For parts B and C, participants suggest using vector analysis to determine the acceleration's magnitude and direction, emphasizing the importance of drawing a force diagram to visualize the forces acting on the ball.
  • Understanding of Newton's second law (f=ma)
  • Familiarity with circular motion equations (a = v²/r)
  • Basic trigonometry, including the use of arctan
  • Ability to draw and interpret force diagrams
  • Learn how to apply Newton's second law in circular motion scenarios
  • Study vector decomposition for forces in circular motion
  • Explore the concept of centripetal acceleration and its calculation
  • Investigate the relationship between tension, gravitational force, and acceleration in pendulum systems
Physics students, educators, and anyone interested in understanding dynamics in circular motion and the forces acting on objects in a gravitational field.
14h54
A 2.0 kg ball swings in a vertical circle on the end of an 80 cm-long string. The tension in the string is 20 N when its angle from the highest point on the circle is theta = 30.
A) What is the ball's speed when theta = 30?
B) What is the magnitude of the ball's acceleration when theta = 30?
C) What is the direction of the ball's acceleration when theta = 30? Give the direction as an angle from the r-axis.
f=ma; a = v2/r
A) T-mgcos(theta)=mv2/r; v=sqrt((t-gcos(theta))*r) which is 3.8 m/s (the correct answer)
I have no idea how to go about finding part b and c. The only thing I may know about part c is that I'll have to use arctan at some point.
Thanks for all the help, I really appreciate it :)
It may be easier to solve for part c first, and then part b. Finding the acceleration vector may be the best thing you can do for yourself right now. I recommend drawing a picture of the force diagram when the ball is at 30 degrees. Will the ball's acceleration always be radially directed outward, always directed along the circular path of the pendulum's motion, or always down with the gravitational force?
And then after finding the direction, square each component, add them, and then square root the sum for magnitude! Hope this helps!
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 19 ·
11K
