Quantum Tunneling Explained: How Does it Work?
The discussion revolves around the concept of quantum tunneling, exploring how it operates within the framework of quantum mechanics. Participants provide explanations and analogies to clarify the phenomenon, touching on both theoretical and conceptual aspects.
  • One participant requests an explanation of quantum tunneling.
  • Another participant uses the analogy of a ball rolling in a bowl to describe how an electron can "tunnel" from one potential well to another without classically overcoming the barrier.
  • It is noted that the probability of tunneling is never zero and can be influenced by the proximity of potential wells and their energy barriers.
  • A claim is made that quantum tunneling is impossible in classical physics due to implications of negative kinetic energy and mass.
  • Several participants express appreciation for the explanations provided.
  • Links to external resources related to quantum tunneling and quantum physics are shared for further exploration.
Participants generally agree on the basic concept of quantum tunneling as described, but there is a disagreement regarding its implications in classical physics, with at least one participant asserting it is impossible under classical conditions.
The discussion includes varying interpretations of quantum tunneling and its relationship to classical physics, with some assumptions about the nature of energy and mass remaining unexamined.
Reshma
Could some please explain me how quantum tunneling works?
When a ball rolls down from the edge of a bowl, it barely reaches the opposite edge and comes back oscillating until friction slows it down to a stop in the bottom of the bowl.
If you reduce your ball to an electron and your bowl to a potential well (see this as a tiny bowl, working with electric fields rather than gravity), not only there is no friction to speak of, but if there is an other "bowl/well" nearby, the electron may jump out of the first bowl and appear in the next without ever reaching the edge of either bowl. This is tunneling. The way it works is by probability. The probability of tunneling is never zero, but can be increased by bringing the bowls/wells closer to each other, or by lowering the edges (even though they can be maintained above what would be required classically for the ball/electron to transfer). Funky huh? That's what's fun about quantum mechanics.
nice explanation by Gonzolo
Quantumtunneling is impossible in classical fysics, because it would imply a negative kinetic energy and thus a negative mass-value...
Thank you for your explanation.It was interesting.
Welcome Reshma !
Welcome to PF, Reshma!
FYI, some related links that I found interesting:
http://zebu.uoregon.edu/~js/ast123/lectures/lec07.html
http://www.comcity.com/distance-time/The%20Speed%20of%20Quantum%20tunneling.html
http://www.physlink.com/Education/AskExperts/ae619.cfm
http://www.altair.org/Qtunnel.html
http://www.nobeliefs.com/light.htm
There is of course, a wealth of resources on the internet related to Quantum Physics. You can find out a lot more simply using google...
Cheers
Vivek
The discussion with what_are_electrons has been split off and moved to the theory development subforum: https://www.physicsforums.com/showthread.php?t=39469
- Warren
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 20 ·
11K
