Momentum, what velocity do i use?
  • Thread starter Thread starter eulo0
    Momentum Velocity
The discussion revolves around a physics experiment involving momentum, specifically focusing on the velocities of colliding carts. The original poster is seeking clarification on which velocity to use for calculating momentum after a collision, given varying velocities recorded during the experiment.
  • The original poster attempts to understand which specific velocity should be used for momentum calculations at the moment of collision. Some participants suggest using the velocity at the point of impact, while others raise questions about the implications of the stationary cart's initial momentum.
Participants are exploring different interpretations of the velocity to be used in momentum calculations. Some guidance has been provided regarding the use of collision point velocity, but there is no explicit consensus on the best approach. The conversation remains open-ended with various perspectives being discussed.
There is a mention of varying velocities recorded during the experiment, and the original poster is grappling with the implications of using a stationary cart in the momentum calculation. The discussion highlights the need for clarity on definitions and assumptions related to momentum and velocity in this context.
eulo0
I have done a cart experiment, were 1 cart collides with another that is stationary in a straight line. i have videotaped my experiment and used logger pro to evaluate my findings. it gives me different velocity's, in each time frame. which velocity do i use to work out the momentum?
i used the equation d=1/2(u+v)t
You simply use the velocity at the point of incident ie at the collision point. Normally in physics you might be expected to deduce the velocity from a function that describes the movement of the rolling cart. You don't need to do this because you have the raw data. Bonus points, though for describing the deceleration of the trolley with an appropriate function and then comparing function with your results. Good luck
thank you
which velocity do i use to work out how much momentum the cart getting hit has if its starts staionary
Momentum is what an object possesses only when it is moving. The equation p=mv states that momentum (p) is equal to mass (m) times velocity (v). Momentum is used as a means to define an object by it's mass and speed. Since your cart was hit whilst stationary it's speed was zero therefore it's momentum was zero.
  • · Replies 40 ·
