How Does Kay's Rule Affect Gas Flow Calculations in Turbines?
  • Thread starter Thread starter Smitts
This discussion focuses on applying Kay's Rule to estimate the inlet flow rate of gas to a turbine in a coal gasification process. The product gas composition is 60.0 mol% CO and 40.0 mol% H2, exiting the plant at 423.14 K and 2,000 psia. The gas expands to a boiler furnace at 373.15 K and 101.325 kPa, with a volumetric flow rate of 424.75 m³/min. The discussion also addresses the percentage error when using the ideal gas equation at the turbine inlet.
  • Understanding of Kay's Rule for gas mixtures
  • Knowledge of gas behavior under varying temperature and pressure conditions
  • Familiarity with volumetric flow rate calculations
  • Basic principles of thermodynamics related to gas expansion
  • Study Kay's Rule in detail and its application in gas flow calculations
  • Learn about the ideal gas law and its limitations in real-world applications
  • Research methods for calculating volumetric flow rates in gas systems
  • Explore thermodynamic properties of CO and H2 under varying conditions
Engineers, process designers, and students involved in chemical engineering, particularly those focusing on gas flow calculations and thermodynamic processes in turbines and gasification plants.
Smitts
Hi I was wondering if anyone could help me with this material balance/gas behaviour question.
"The product gas from a coal gasification plant consists of 60.0 mol% CO and the balance H2. It leaves the plant at 423.14 kelvins and 2,000 psia. The gas expands through a turbine and is fed to a boiler furnace at 373.15 kelvins and 101.325 kPa at a rate of 424.75 m3/min. Estimate the inlet flow rate to the turbine in m3/h, using Kay’s rule.
What percentage error would result from the use of the ideal gas equation at the turbine inlet? "
I have no idea how to start so any help would be much appreciated!
To start, how about writing Kay's rule.
Also right the values given, such as temperature, pressure, volumetric flow rate, and gas composition. The determine the unknown value for which one is solving.
9K
