Light Momentum & Photography: Facts & Effects
  • Context: Undergrad
  • Thread starter Thread starter uzair_ha91
    Light Momentum
The thread discusses the relationship between light, momentum, and photography, specifically addressing how light interacts with surfaces and the implications for photographic processes. It explores concepts of light pressure, wavelength sensitivity in photography, and the effects of light on objects in space.
  • One participant claims that only red light is used in photography due to its low energy, which supposedly does not affect photographic plates.
  • Another participant asserts that any surface interacting with light experiences a small pressure, with reflection potentially doubling this pressure, and mentions solar sails as a practical application.
  • A participant challenges the initial claim about red light, suggesting that the issue is more about wavelength sensitivity rather than energy levels, and questions whether film photography can capture red objects.
  • One participant states that wavelength is inversely proportional to energy and extends the discussion by asking if shining light on an object in space would cause it to move.
  • A later reply reiterates the question about whether shining light on an object in space will cause movement, referencing solar sails again.
Participants express differing views on the role of red light in photography and the relationship between light energy and wavelength. The discussion remains unresolved regarding the implications of light momentum on objects in space.
There are unresolved assumptions about the sensitivity of photographic materials to different wavelengths and the specific mechanics of light pressure on surfaces.
uzair_ha91
I've read somewhere that only red light is used in photography because of its low energy which does not affect the photographic plate.
So my question is that when light shines on a surface, is momentum transferred to the metal surface?
Yes, any surface that reflects, absorbs or emits light will effectively act as if light imparted a very small pressure on it. Reflection, which can be thought of as an absorption followed by an emission more or less back the same way, gives up to twice the pressure. Light (including heat from black-body radiation) emitted from the "the other side" of the surface will of course reduce the effective pressure.
You can look up how solar sails work to see a "practical" application of this effect.
uzair_ha91 said:
I've read somewhere that only red light is used in photography because of its low energy which does not affect the photographic plate.QUOTE]
I hope your not suggesting that film photography cannot photograph something red?
Perhaps the special "red light" used in developing rooms are of such a wavelength that the photographic dyes are not sensitive to.
Thus, I think this has more to do with wavelength sensitivity rather than "energy" levels.
Just my thoughts... could be wrong.
Wavelength is inversely proportional to energy, or something like that.
As an extension of the topic "momentum of light", if you shine light on an object in space, will the object start moving?
Solar Sail
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 35 ·
  • · Replies 20 ·
