Differentials, pseudo-differentials, and locality
  • Context: Graduate
  • Thread starter Thread starter jostpuur
    Differentials Locality
The discussion centers on the properties of differential and pseudo-differential operators, particularly in relation to compact support and instantaneous spreading. Claims established include that if \(\psi(x,0)\) has compact support, then \(\psi(x,t)\) does not for \(t>0\) under both the non-relativistic Schrödinger equation \(i\partial_t\psi(x,t) = -\partial_x^2\psi(x,t)\) and the pseudo-differential operator \(i\partial_t\psi(x,t) = \sqrt{1 - \partial_x^2}\psi(x,t)\). The conversation also highlights the locality properties of these operators, concluding that the pseudo-differential operator does not possess the locality property in the same way as the ordinary differential operator. The discussion emphasizes the need for rigorous proofs regarding the instantaneous spreading behavior of these equations.
  • Understanding of differential equations, specifically the non-relativistic Schrödinger equation.
  • Familiarity with pseudo-differential operators and their properties.
  • Knowledge of compact support in the context of functions and distributions.
  • Basic concepts of Fourier transforms and their implications on function behavior.
  • Research the properties of pseudo-differential operators, focusing on locality and non-locality.
  • Study the implications of compact support in solutions to differential equations.
  • Explore the relationship between Fourier transforms and the behavior of functions with compact support.
  • Investigate rigorous proofs regarding instantaneous spreading in solutions to the non-relativistic Schrödinger equation.
Mathematicians, physicists, and researchers in applied mathematics who are exploring the behavior of differential equations, particularly in quantum mechanics and mathematical physics.
jostpuur
Claim 1:
If [itex]\psi(x,0)[/itex] has a compact support, and
[tex] i\partial_t\psi(x,t) = -\partial_x^2 \psi(x,t),[/tex]
then [itex]\psi(x,t)[/itex] does not have a compact support for any [itex]t>0[/itex].
Claim 2:
If [itex]\psi_1[/itex] and [itex]\psi_2[/itex] are the same in some environment of a point [itex]x_0[/itex], then
[tex] \partial_x^2 \psi_1(x_0) = \partial_x^2 \psi_2(x_0)[/tex]
Claim 3:
[tex] i\partial_t\psi(x,t) = \sqrt{1 - \partial_x^2} \psi(x,t),[/tex]
Question:
If [itex]\psi_1[/itex] and [itex]\psi_2[/itex] are the same in some environment of [itex]x_0[/itex], will it follow that
[tex] \sqrt{1 - \partial_x^2}\psi_1(x_0) = \sqrt{1 - \partial_x^2}\psi_2(x_0)?[/tex]
Thoughts:
According to my understanding, at least with some assumptions, the claims 1,2,3 are all true. If I had not mentioned the claims 1 and 2, some people might have answered to my question, that the pseudo-differential operator [itex]\sqrt{1 - \partial_x^2}[/itex] does not possesses the locality property I'm asking in the question, because we know that it is non-local in the sense of the claim 3. However, we know that the ordinary differential operator [itex]\partial_x^2[/itex] has the non-locality property in the sense of claim 1 too, and still it has the locality property in the sense of claim 2. So without better knowledge, it could be that the pseudo-differential operator has this locality property too. But what's the truth?
I think that the answer to my question is "no", and the instantaneous spreading caused by [tex]\sqrt{1 - \partial_x^2}[/tex] is significantly faster than the instantaneous spreading caused by [tex]\partial_x^2[/tex].
I just realized that I don't yet know how to prove that the non-relativistic Schrödinger equation causes instantaneous spreading. Here's the problem:
If we want to satisfy the heat equation
[tex] \partial_t u(t,x) = \partial_x^2 u(t,x)[/tex]
with some initial condition [itex]u(0,x)\geq 0[/itex] which has compact support, we can accomplish it with a formula
[tex] u(t,x) = \frac{1}{\sqrt{4\pi t}}\int\limits_{-\infty}^{\infty} \exp\Big(-\frac{y^2}{4t}\Big) u(0,x-y)dy.[/tex]
It can be seen from this formula that [itex]u(t,x)>0[/itex] for all [itex]t>0[/itex]. Hence the compact support is lost instantaneously.
But the take a closer look at the non-relativistic Schrödinger equation. We want
[tex] i\partial_t \psi(t,x) = -\partial_x^2\psi(t,x)[/tex]
with some initial condition [itex]\psi(0,x)[/itex] with compact support. The solution can be written as
[tex] \psi(t,x) = \frac{1}{\sqrt{4\pi t}}\int\limits_{-\infty}^{\infty} \exp\Big(\frac{iy^2}{4t}\Big) \psi(0,x-y)dy.[/tex]
But how do you prove that [itex]\psi(t,x)[/itex] does not have a compact support for [itex]t>0[/itex]? It's not so obvious now because there could be some canceling in the integral.
I'm interested in rigor comments only! (Or comments that at least attempt some rigor. I'm not sure if I'm perfectly rigorous either...).
I know some physicists like to say that "well look at the propagator. It is non-zero for arbitrarily large intervals, and hence the instantaneous spreading." You might as well try to insist that Fourier transforms (or inverse transforms) will never give functions with compact support, because the plane waves extend to infinities. Of course canceling can occur!
An interesting remark about the heat equation is that if we fix some [itex]x'[/itex] outside the original compact support, then the Taylor series
[tex] u(0,x') + t \partial_t u(0,x') + \frac{1}{2!} t^2 \partial_t^2 u(0,x') + \cdots = 0[/tex]
is identically zero, even though [itex]u(t,x')>0[/itex] for arbitrarily small [itex]t>0[/itex]. This means that the spreading is extremely slow, at least for small [itex]t[/itex].
The same slowness does not occur for relativistic Schrödinger equation. If [itex]\psi(0,x)[/itex] has a compact support, then [tex]\hat{\psi}(0,p)[/tex] is analytic. But
[tex] i\partial_t\hat{\psi}(0,p) = \sqrt{1 + p^2}\hat{\psi}(0,p)[/tex]
is not analytic because of the branch cuts at [itex]p=\pm i[/itex]. Hence [itex]\partial_t\psi(0,x)[/itex] does not have a compact support, and the instantaneous spreading is faster than with the heat equation.
  • · Replies 17 ·
