| Thread Closed |
Find the magnitude of the acceleration of the two masses. |
Share Thread | Thread Tools |
| Mar28-10, 05:17 PM | #1 |
An Atwood machine consists of two masses (16.4 kg and a 2.9 kg) strung over a 0.43 m diameter pulley whose moment of inertia is 0.031 kg·m2. If there is a constant friction torque of 0.18 N·m at the bearing, compute the magnitude of the acceleration of the two masses. Can someone just tell me where to start please? |
| Mar28-10, 06:01 PM | #2 |
Not sure if there's more information than the needed in that problem, but first of all you should think for instance of the relation of the moment of inertia and torque.
[tex]\tau = I\alpha [/tex] |
| Mar28-10, 06:24 PM | #3 |
Maybe I wasn't explicit enough, but to begin with this problem you will first need to state the tension of the string (T=mg-ma). With that you will be able to find the 'applied torque' in terms of the acceleration:
[tex]\tau_a = (mg - ma)r[/tex] And once you have this, you will be able to easily use the formula I wrote in the last post. Note that: [tex]\tau_a - \tau_f = \tau[/tex] and: [tex]\alpha = a/r[/tex]. |
| Mar28-10, 06:46 PM | #4 |
[QUOTE=Redsummers;2644285]Maybe I wasn't explicit enough, but to begin with this problem you will first need to state the tension of the string (T=mg-ma). With that you will be able to find the 'applied torque' in terms of the acceleration:
[tex]\tau_a = (mg - ma)r[/tex] Is m the total mass of both masses? |
| Mar28-10, 07:36 PM | #5 |
[tex](T_1 - T_2)r - \tau_f = I\alpha[/tex] and according to Newton's concerning the tensions: [tex]m_1g - T_1 = m_1a[/tex] [tex]m_2g - T_2 = m_2a[/tex] Thus, [tex](T_1 - T_2)r = I\alpha + \tau_f [/tex] [tex](T_1 - T_2) = \frac{Ia}{r} + \tau_f[/tex] [tex]T_1 - T_2 = \frac{Ia}{r} + \tau_f [/tex] And now you would have to plug the tension equations stated above, and do the maths to get the acceleration. |
| Mar28-10, 08:16 PM | #6 |
Where does the part about "constant friction torque of 0.18 N·m at the bearing" come in to play?
| Mar29-10, 05:16 AM | #7 |
oh the constant friction torque is simply represented as
[tex]\tau_f[/tex] It is, as the name represents the friction done by the pulley to the string. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Find the magnitude of the acceleration of the two masses.
| Magnitude of Acceleration of Masses | Introductory Physics Homework | 6 | ||
| Find the normal force and magnitude of acceleration. | Introductory Physics Homework | 4 | ||
| Find the magnitude of acceleration of the puck on the ramp | Introductory Physics Homework | 1 | ||
| Find the magnitude of the acceleration of the particle. | Introductory Physics Homework | 4 | ||
| Three masses on a frictionless surface. Find Acceleration and tension. | Introductory Physics Homework | 1 | ||
