Primitive Pyth. triples: Solutions of x^2 + y^2 = 2 z^2
  • Context: Graduate
  • Thread starter Thread starter kingwinner
    Primitive
The discussion centers on the characterization of all solutions to the equation x² + y² = 2z² using the theorem for primitive Pythagorean triples. The theorem states that positive primitive solutions can be expressed as x = r² - s², y = 2rs, z = r² + s², where r and s are integers of opposite parity, r > s > 0, and gcd(r, s) = 1. The participants conclude that while the first form (i) includes all Pythagorean triples by introducing a natural number d, the second form (ii) is insufficient as it does not account for all possible integer solutions. The final characterization of all integer solutions includes both positive and negative integers, as well as zero.
  • Understanding of Pythagorean triples
  • Familiarity with integer properties and gcd (greatest common divisor)
  • Knowledge of algebraic manipulation and solving linear equations
  • Basic concepts of number theory, particularly regarding parity
  • Study the derivation of Pythagorean triples using the Euclidean algorithm
  • Explore the implications of parity in number theory
  • Learn about integer solutions to quadratic equations
  • Investigate the generalizations of Pythagorean triples in higher dimensions
Mathematicians, students of number theory, and anyone interested in the properties and solutions of Pythagorean equations.
kingwinner
Theorem: The positive primitive solutions of x^2 + y^2 = z^2 with y even are x = r^2 - s^2, y = 2rs, z = r^2 + s^2, where r and s are arbitrary integers of opposite parity with r>s>0 and gcd(r,s)=1.
Using this theorem, find all solutions of the equation x^2 + y^2 = 2z^2
(hint: write the equation in the form (x+y)^2 + (x-y)^2 = (2z)^2)
The above theorem characterizes all "PRIMITIVE Pythagorean triples", but what is the statement of the theorem that characterizes ALL "Pythagorean triples" (not necessarily primitive)?
(i) The positive solutions of x^2 + y^2 = z^2 with y even are precisely x = (r^2 - s^2)d, y = (2rs)d, z = (r^2 + s^2)d, where d is any natural number, r and s are arbitrary integers of opposite parity with r>s>0 and gcd(r,s)=1.
(ii) The positive solutions of x^2 + y^2 = z^2 with y even are precisely x = r^2 - s^2, y = 2rs, z = r^2 + s^2, where r and s are arbitrary integers with r>s>0.
Which one is correct?
I hope someone can help me out. Thank you!
The only difference is a d, which, as it says, represents any natural number.
So I think (i) correctly characterizes ALL Pythagorean triples.
Is (ii) wrong?
i.e. not all Pythagorean triple is of the form x = r^2 - s^2, y = 2rs, z = r^2 + s^2, r>s>0?
For example, 6,8,10 is a Pythagorean triple, but I think it cannot be written in the above form?
The most important triples are the fundamental or primitative ones. We can always add a constant to all elements in any triple.
If you can read through the proof of (2), which starts from scratch, you will get a better understanding of this.
But can EVERY Pythagorean triple (primitive or imprimitive) be written in the form x = r^2 - s^2, y = 2rs, z = r^2 + s^2 for some r,s E Z, r>s>0?
No. For example, 9^2 + 12^2 = 15^2, but 15 cannot be written as the sum of two squares.
Petek
Petek
OK, so (i) is correct and (ii) is wrong.
Back to our original problem...
x^2+y^2=2z^2\iff(x+y)^2+(x-y)^2=(2z)^2
<=> x+y,x-y,2z is a Pythagorean triple (but it's not necessarily primitive)
\begin{cases} x+y=(m^2-n^2)d\\x-y=2mnd\\2z=(m^2+n^2)d \end{cases}
where d is natural number, m and n are integers of opposite parity with m>n>0 and gcd(m,n)=1.
Now how can we characterize ALL solutions of x^2 + y^2 = 2z^2? Is there any restriction on "d"?
Thank you!
If d is any natural number, then x+y, x-y, and 2z form a Pythagorean triple. Now just follow your "if and only ifs" in reverse to conclude that x^2 + y^2 = 2z^2.
But I believe that when we're asked to find all solutions of the equation x^2 + y^2 = 2z^2, the answer should be of the form
x=...
y=...
z=...
How can we get this?
x=...
y=...
z=...
Well, you can solve these three equations for x, y, and z:
<br /> \begin{cases} x+y=(m^2-n^2)d\\x-y=2mnd\\2z=(m^2+n^2)d \end{cases} <br />
The first two are a linear system of two equations with two unknowns (x and y) so should be easy to solve. The third one is even easier - just divide both sides by 2.
Is that what you meant?
[Edit]: Hmm, I guess you will have to impose constraint(s) to ensure that the solutions are integers.
For example:
z = \frac{1}{2}(m^2 + n^2)d
We're still assuming that m and n have opposite parity, right? That means m^2 + n^2 is odd, so d had better be even. You will have to check x and y as well once you have expressions for them.
Sovling for x,y,z, I get:
x = d(m^2 - n^2 + 2mn) / 2
y = d(m^2 - n^2 - 2mn) / 2
z = d(m^2 + n^2) / 2
So d must be even, is this the ONLY restriction?
Yes, that looks like the only restriction.
So I think the final answer is
x = d(r^2 - s^2 + 2rs) / 2
y = d(r^2 - s^2 - 2rs) / 2
z = d(r^2 + s^2) / 2
where d is any EVEN natural number, r and s are any integers of opposite parity with r>s>0 and gcd(r,s)=1?
Does this include ALL solutions of x^2 + y^2 = 2z^2?
OK, now I've thought about it more, and I think that are serious problems in my formula above. We're actually missing A LOT of solutions. For example, x=y=z is a solution for any integer (e.g. x=y=z=6 is a solution), but it's definitely not a Pythagorean triple, the formula above misses all of those. Also, all the negative solutions are missing from the above formula because by definition a Pythagorean triple is positive while solutions to the equation can be positive or negative.
So the above formula certainly does not include all solutions, how can we fix this problem? How can we correctly write down a formula that includes all the solutions?
Can someone kindly explain how we can summarize our final answer that includes all solutions into a compact formula?
Thanks a million!
x = y = z isn't a solution to x^2 + y^2 = z^2 but it is a solution to (x +y)^2 + (x - y)^2 = (2z)^2. That is,
(x + x)^2 + (x - x)^2 = (2x)^2
Petek
If I want to solve x^2 + y^2 = 2z^2 in the integers (rather than in the natural numbers), i.e. x,y,z E Z, what would be the answer? How can we fully describe the set of ALL integer solutions? Right now, I'm having a lot of trouble trying to describe ALL integer solutions without missing any. Does anyone happen to know the correct answer?
Thanks!
The solutions in integers are just
(x, y, z)
(-x, y, z)
(x, -y, z)
(-x, -y, z)
(x, y, -z)
(-x, y, -z)
(x, -y, -z)
(-x, -y, -z)
for every solution (x, y, z) in positive integers, together with (0, 0, 0).
  • · Replies 26 ·
  • · Replies 17 ·
