Prove that ord(a) = ord(bab^(-1))
  • Thread starter Thread starter The_Iceflash
The discussion revolves around proving that the order of an element a in a group is equal to the order of the element bab^(-1). Participants are attempting to establish this by showing that if ord(a) = n, then (bab^(-1))^n = e, using the associative property of group operations. There is some confusion regarding the structure of the proof, with suggestions to treat it as a two-part proof versus a more unified approach. The conclusion drawn is that both orders must either be finite and equal or infinite. Clarification on the rationale behind the proof structure is also discussed, emphasizing the need to consider both finite and infinite cases.
The_Iceflash
Prove that ord(a) = ord(bab^(-1)) (Edited/Fixed)
Prove that ord(a) = ord(bab-1)
N/A
Part 1: Show that ord(bab-1) = n
Suppose that ord(a) = n
Then an = e.
I then have to use the associative law to show (bab-1)n = e but that's where I'm having troublem.
Part 2: Show that ord(a) = n
Suppose ord(bab-1) = e
Then (bab-1)n = e
I then have to use the associative law to show that an = e but I'm stuck there as well.
Help is greatly appreciated.
I fixed the many typos I had.
Try writing out the multiplication:
(bab^{-1})^n = (bab^{-1})(bab^{-1})\cdots (bab^{-1}) (product of n identical terms)
and simplifiy.
and simplifiy.
So, doing that I get this:
(bab^{-1})^n = (bab^{-1})(bab^{-1})\cdots (bab^{-1}) = ba^nb^{-1} = beb^{-1} = bb^{-1} = e
Is that a valid thing to do?
On that thought, How would I show a^n = e for part 2?
Yes, it's valid. So this shows that (bab^{-1})^n = e. It does NOT necessarily follow that o(bab^{-1}) = n, because there could be some smaller exponent k such that (bab^{-1})^k = e. You have to do a little more work to prove that this can't happen.
I'm not sure why you think this is a two-part proof. You want to prove that
o(a) = o(bab^{-1})
So let n = o(a), and then prove that o(bab^{-1}) = n and you're done.
Ok.
o(a) = o(bab^{-1})
That's how my professor outlined the proof for me. They broke it up into two parts. The conclusion that is to come out of that as well is that doing both parts will prove that both orders are either infinite or both finite and equal. I believe that's why they want it broken up into two parts.
I'm not sure I understand the prof's rationale. Structuring the proof as
"Part 1: show that o(bab^{-1}) = n
Part 2: show that o(a) = n"
begs the question: what is n? I don't see how this helps address the finite vs. infinite cases. More natural would seem:
"Part 1: Suppose that o(a) = n < \infty. Show that o(bab^{-1}) = n
Part 2: Suppose that o(a) = \infty. Show that o(bab^{-1}) = \infty"
  • · Replies 23 ·
