Moment of Inertia: Find Answers to 2 Problems
This discussion addresses the calculation of the moment of inertia for two different shapes: a rod and a disk. For the rod, the moment of inertia is derived using the formula I = A * (L/2)^3 / 3, simplifying to 1/12 * A * L^2, where A represents the linear density. For the disk, the moment of inertia is calculated using I = k * integral of r dA from 0 to R, leading to I = 1/2 * Q * m * R, where Q is the mass density defined as Q = k/r. Both problems emphasize the importance of substituting given values into the formulas rather than treating them as variables.
  • Understanding of moment of inertia concepts
  • Familiarity with calculus, specifically integration
  • Knowledge of mass density and linear density
  • Basic principles of rotational dynamics
  • Study the derivation of moment of inertia for various shapes, including rods and disks
  • Learn about the application of integration in physics problems
  • Explore the relationship between mass density and volume in three-dimensional objects
  • Investigate the effects of varying density on moment of inertia calculations
Students and professionals in physics, mechanical engineering, and applied mathematics who are focused on understanding the principles of rotational motion and moment of inertia calculations.
mr_joshua
There are 2 questions that are giving a few of us problems.
1. Find the moment of inertia of a rod about an axis through its center if the mass per unit length is A=A*x A is linear density. This is a simple problem, but we are not sure how to use the given value for A (linear density). so far we have I=A * intergral of x^2 dx from 0 to L/2. which you finally get 1/12ML^2...
2. Same type of inertia problem except this is a disk about its center where mass density Q (which in normal cases is dm/dA) here Q=Q*r^(-1)
Please help.
The statements
- A = A*x
- Q = Q*r^(-1)
don't make any sense.
Remember the definition of moment of inertia:
[tex]\int_V \rho(\mathbf{r})dV(r\sin\theta)^2[/tex]
where θ is the angle between r and the axis of rotation and ρ(r) dV is the mass element at location r. If ρ(r) isn't constant you can't take it out of the integral.
For the first problem, the moment of inertia of a rod about an axis through its center can be found by using the formula I = A * integral of x^2 dx from 0 to L/2, where A is the linear density and L is the length of the rod. This formula assumes that the rod has a uniform density along its length. To use the given value for A, you simply substitute it into the formula instead of using a variable. So, the final answer would be I = A * (L/2)^3 / 3, which simplifies to 1/12 * A * L^2. This is the same answer you got, but it's important to note that A is not a variable, but a given value.
For the second problem, the moment of inertia of a disk about its center can be found by using the formula I = Q * integral of r^2 dA, where Q is the mass density and r is the distance from the axis to the element of area dA. In this case, Q is given as Q = Q * r^-1, which means that Q is inversely proportional to r. This can be rewritten as Q = k/r, where k is a constant. Substituting this into the formula, we get I = k * integral of r dA from 0 to R, where R is the radius of the disk. This integral can be simplified using the formula for the moment of inertia of a disk, which is I = 1/2 * m * R^2, where m is the mass of the disk. So, the final answer would be I = k * 1/2 * m * R^2, which simplifies to 1/2 * Q * m * R. Again, it's important to note that Q is not a variable, but a given value.
  • · Replies 40 ·
