Solve Inequalities: Find p Values for p(x^2+x) < 2x^2 + 6x +1
  • Thread starter Thread starter garytse86
    Inequalities
The discussion revolves around solving the inequality p(x^2+x) < 2x^2 + 6x + 1, with participants attempting to determine the set of values for p that satisfy this condition for all real x. The problem involves understanding quadratic inequalities and their discriminants.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore different forms of the inequality and discuss the implications of the discriminant being negative for the quadratic expressions involved. There are attempts to clarify the conditions under which the inequality holds true for all x, including discussions about the nature of roots and the behavior of quadratic functions.
The discussion is ongoing, with various interpretations and approaches being explored. Some participants have suggested that the original inequality may have been misstated, leading to confusion. There is a mix of agreement and questioning regarding the conditions for p, particularly in relation to the discriminant and the nature of the quadratic functions involved.
Participants are grappling with the implications of different forms of the inequality, and there is uncertainty about the correctness of the textbook answer. The discussion highlights the need for clarity in the setup of the problem and the assumptions made regarding the values of p.
garytse86
Can someone help me please with inequalities, I have been attempting this question quite a few times but I still can't get the same answer as the textbook.
What is the set values of p for which p(x^2+x) < 2x^2 + 6x +1 for all real values of x?
Here is my best attempt:
px^2 + 2p - 2x^2 - 6x -1 < 0
(p-2)x^2 - 6x + 2p -1 < 0
For real roots b^2 - 4ac >= 0
so 6^2 - 4 * (p-2) * (2p-1) >= 0
36 - (8p^2 - 20p + 8) >= 0
-8p^2 + 20p + 28 >= 0
root 1: (-20 + (400 - (4 * -8 * 28)) ^ 1/2) / -16 >= 0
root 1: -20/-16 + (1296^1/2)/16
root 1: 400/256 + 1296/256
= 1696/256
root 2: (-20 - (400 - (4 * -8 * 28)) ^ 1/2) / -16 >= 0
root 2: -20/-16 - (1296^1/2)/16
root 2: 400/256 - 1296/256
= -896/256
That's as far as I have got...
the answer in the textbook is p < -1
Can you please help... Thanks a lot.
Gary.
There's a mistake...
Not "px^2 + 2p - 2x^2 - 6x -1 < 0"...
but...px^2 + p*x - 2x^2 - 6x -1 < 0...
(p-2)*x^2+(p-6)*x-1<0
delta=p^2-12p+36+4p-8...
delta=p^2-8p+28...
I) If p-2>0 then there's no solution...it has a "minimus?"...
II) If p-2<=0 then...
delta<0
p^2-8p+28<0
p^2-8p+16+12<0
(p-4)^2+12<0...which is impossible...so there's no such p...
Are you sure the text is correct ?
i am really sorry, the question should be:
p(x^2+2) < 2x^2 + 6x +1
not
Then we have...
(p-2)*x^2-6*x+(2p-1)<0
Evidently p-2<0...the function has a "maximum"...
delta=36-4(2p-1)(p-2)...
delta=36-4(2p^2-5p+2)...
delta=36-8p^2+20p-8...
delta<0...no real solutions...
-8*p^2+20*p+28<0...
2*p^2-5*p-7>0...
dp->delta for this ecuation...
dp=25+56...
dp=81...
p1=(5-9)/4=-1...
p2=(5+9)/4=7/2...
because a in this ecuation is >0...p is in (-inf,-1)U(7/2,+inf)...
now...because p-2<0...p<2...results that p<-1...
Got it ?
How do you know this?
let f(x)=a*x^2+b*x+c...
f'(x)=2*a*x+b
f''(x)=2*a
where f'(x)=0 you'll have an "extremum"...
f'(x0)=2*a*x0+b=0...x0=-b/(2*a)...
f''(x0)=2*a...if f''(x0)>0 then in x0 the concavity is upward...
else it is downward...so...if a>0 the function looks like this \/...and if a<0 then it looks like this /\...got it now ?
-8*p^2+20*p+28<0...
Then shouldn't the last line be:
-8*p^2+20*p+28>0...
In the textbook it showed the calculations exactly the same way you did, that's what I don't get.
Would you mind explaining this?
Here's how I would do this problem:
p(x^2+2) < 2x^2 + 6x +1 is the same as
px^2+ 2p< 2x^2+ 6x+ 1 or (2-p)x^2+ 6x+ (1-2p)> 0 for all x.
If this is never 0, then it's discriminant must be negative:
36- 4(2-p)(1-2p)< 0
(The inequality is <0 so that the discrimant is negative and there are no real roots.)
-8p^2+ 20p+ 28< 0
2p^2- 5p- 7> 0
2p^2- 5p- 7= 0 has roots -1 and 7/2.
2p^2- 5p- 7> 0 for x< -1 and x> 7/2.
Putting x= -2 (less than -1) into the original inequality, we find that p(x^2+2) < 2x^2 + 6x +1 for p< -1- the result we want.
Putting x= 3 (greater than 7/2) into the original inequality, we find that p(x^2+2) > 2x^2 + 6x +1 for p> 7/2- not what we want.
The original inequality is true for all x as long as p< -1.
-8*p^2+20*p+28<0...
if delta<0 then the function doesn't intersect OX...and because it looks like /\...it must be under OX for every x...got it ?
Question: What is the set values of p for which p(x^2+x) < 2x^2 + 6x +1 for all real values of x?
Quote: for all real values of x?
Then b^2 - 4ac > 0 should be true not
b^2 - 4ac < 0
thats what I don't understand, and I really appreciate your help!
b^2 - 4ac < 0
Well, first, you are back to "x^2+ x" which you told us was incorrect. I'm going to assume you meant p(x^2+2) < 2x^2 + 6x +1.
As far as "b^2- 4ac" is concerned you have it backwards.
If ax^2+ bx+ c> 0 (or <0) for all x, then ax^2+ bx+ c must have NO real solutions. That means the two roots that any quadratic has must both be complex: the discriminant, b^2- 4ac must be negative.
if that delta is non-negative then the ecuation would have at least one solution...that means the inequality would be <=...not <...
...draw the graphic of the function...and you'll see...try it with both a<0...and a>0...and delta<0...and delta>0...and it will become clear...
HallsofIvy, ax^2+bx+c > 0 does not mean both roots are not real.
consider x^2 + 2x + 3 > 0, the roots are not complex.
I may not be very bright, but I can at least use the quadratic formula: the roots of x^2 + 2x + 3 = 0 are (-2+/- sqrt(4-12))/2=
-1 +/- sqrt(2)i and definitely ARE complex.
Saying that ax^2+ bx+ c> 0 (or ax^2+ bx+ c< 0) for all x means that it is never EQUAL to 0 for any real x. The roots of the equation MUST be complex.
sorry that wasn't meant to be offensive.
but consider x^2 + 3x + 2 = 0, the roots are real.
Yes, the roots of x^2 + 3x + 2 = (x+2)(x+1)= 0 are x= -1 and x= -2. It follows FROM THAT that x^2+ 3x+ 2< 0 for -2< x< -1 and that
x^2+ 3x+ 2> 0 for x< -2 or x> -1.
The point, once again, is that the roots of ax^2+ bx+ c= 0 are (by definition) places where the value is 0. If the ax^2+ bx+ c> 0 or ax^2+ bx+ c< 0 for ALL X, then there is NO place where the value is 0 ans so no real value of x for which the equation is satisfied: the roots MUST be complex and b^2- 4ac must be negative.
  • · Replies 24 ·
