Elastic collision of hockey puck
The discussion focuses on calculating the final speed of hockey puck A after an elastic collision with puck B, both having the same mass. Puck A initially travels at 15.2 m/s and is deflected at an angle of 30.0 degrees. The conservation of momentum and kinetic energy equations are applied to solve for the final velocities. The key conclusion is that the angle between the two pucks after the collision can be determined using the conservation of energy equation, leading to the necessary calculations for the final speeds.
  • Understanding of conservation of momentum in elastic collisions
  • Knowledge of conservation of kinetic energy principles
  • Familiarity with vector components in physics
  • Ability to solve quadratic equations
  • Study the principles of elastic collisions in two dimensions
  • Learn how to apply conservation laws in physics problems
  • Explore vector decomposition and its applications in collision problems
  • Practice solving problems involving angular momentum and energy conservation
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators looking for practical examples of elastic collisions.
mybrohshi5
Hockey puck B rests on a smooth ice surface and is struck by a second puck A, which has the same mass. Puck A is initially traveling at 15.2 m/s and is deflected 30.0^\circ from its initial direction. The pucks are made of superball-like material, so you may assume that the collision is perfectly elastic.
Find the final speed of the puck A after the collision
conservation of momentum for one object at rest (1)
mvai = mvaf + mvbf
conservation of kinetic energy (2)
1/2mvai = 1/2mvaf + 1/2mvbf
I have tried this about 10 times and cannot get it right :(
i solved equation 1 for the x and y components of the velocity final for puck b
vbxf = vaxi - vaxf
vbyf = -vayf
so
vbf = sqrt [(vaxi - vaxf)2 + (-vayf)2]
vbf = sqrt [vaxi2 - 2vaxf + vaxf2 + vayf2]
then i plugged this into 1/2mvai = 1/2mvaf + 1/2mvbf for v_bf
i would show all my steps of reducing but it would take forever.
i end up getting vfa = cos(30) = .866 but this is wrong
am i right up to this point of what i have done?
any help would be great. Thank you
The directional components of momentum before and after are the same. So:
[tex]mv_{ai} = mv_{af}cos(\alpha) + mv_{bf}cos(\theta)[/tex] and
[tex]mv_{af}sin(\alpha) + mv_{bf}sin(\theta) = 0[/tex]
Now the trick is to realize that the conservation of energy equation gives you the angle between the two pucks after collision:
[tex]v_{ai}^2 = v_{af}^2 + v_{bf}^2[/tex]
so with that angle you can find [itex]\alpha[/itex]
AM
  • · Replies 35 ·
