| Thread Closed |
Complex integration. |
Share Thread | Thread Tools |
| Apr1-10, 08:13 AM | #1 |
I was told to post this kind of question on the homework help section by one of the mentors,even though I'm not sure it is appropiate. Anyway,I'm doing complex integration now,so I need to get some important concepts cleared. I'll post my doubts in points... 1.firstly,in complex integration,only curves with nonzero and continuous derivatives are considered....but usually,for integration,all we need,is to take a continous curve,with a derivative defined at each point,not necessarily a non-zero derivative. 2. Whenever I read about complex integration,it's always line integrals....isn't the riemann sum concept of integration applicable to complex functions,where we're simply calculating the area under a curve? 3.Why is simple connectedness a necessary condition for complex integration? (my book says it's necessary everywhere,without stating any specific reason.) 4.In complex integration,does integration refer to 'integration over a certain curve',or over a certain 'domain area'? 5. It is found that the complex integrals between two fixed points taken over different paths are not always equal...this is the same in real functions isn't it? In that respect,we could perhaps introduce the concept of 'conservative fields as we do in vector calculus' to complex integrals,....but we don't..why? I f we did,we could find out those complex functions that are path independant by using curl=0. 2. Relevant equations 3. The attempt at a solution |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr8-10, 02:21 PM | #2 |
It's been a week now...and still no replies :(
| Apr8-10, 04:18 PM | #3 |
1.Are you sure about your statement? I frequently encountered integrations along a square or rectangular contour.
2. There's no contradiction, line integrals can be defined in terms of riemann sum 3. The reason, i guess, is that the referred complex integrals only specify the limits of integration(for analytic integrands), then the reason is the same as in the vector calculus, you need simple connectedness to ensure the field is conserved. But if the contour is specified, i don't think simple connectedness is really necessary 4. By the way it is defined, it should be 'integration over a certain curve' 5. Sure, you can view the analytic functions as curl=0 vector field, according to cauchy-riemann condition (actually CR condition is even stronger than curl=0 if i'm correct), and in complex analysis analytic functions are what we primarily focus on |
| Apr9-10, 10:56 AM | #4 |
Complex integration.....on wikipedia,it says that the line integrals and surface integrals are distinct from ordinary intergrals,since they represent weighted sums....inspite of this,can we indeed define line integrals in terms of riemann sum? How do I explain this ? Clearly,here, we don't consider a particular curve...we are considering a region. Thanks for replying,kof9595995. |
| Apr9-10, 11:27 AM | #5 |
You can see the derivation starts from the Riemann sum definition. "and only when the result is consistent for all these integrals,we say it is continuos at that point." I really can't figure out what you meant, why define continuity in terms of integrals?? i've never seen it before(I don't even know if it's possible to define it that way) |
| Apr10-10, 12:58 AM | #6 |
"Complex definite integrals are called(complex) line integrals. The integrand f(z) is integrated over a given curve C in the complex plane,called the path of integration. We assume C to be a smooth curve,that is,C has a continuous and non zero derivative dz/dt at each point.Geometrically,this means that C has a unique and continuously turning tangent." Then,they continue to defiine integrals,and so on. |
| Apr10-10, 01:20 AM | #7 |
By the way,in Kreysig,they define two methods of integration...the first one is supposed to be only for analytic functions,and the second is for any complex function.....why do we distinguish the process of integration for analytic and non analytic functions?
The first method is said to be the analogue of the formula from calculus.and is said to be an indefinitie integral....however,the author puts limits in the integral,so it;s hard to see why it is indefinite. The first theorem says, Let f(z) be analytic in a simply connected domain D.Then there exists an indefinite integral of f(z) in the domain D and for all paths in D joining two points Zo and Z1 in D,we have (integral within limits Zo to Z1)f(z)dz =F(Z1)-F(zo). The second theorem is : Let C be a piecewise smooth path,represented by z=z(t), where t lies between a and b.Let f(z) be a continuous function on C,then the integral of f(z) over C= (integral within limits a to b)f(z)dz = (integral within limits a to b)f[z(t)]z'(t)dt (Sorry,I don;t know how to use latex codes). |
| Apr10-10, 05:30 AM | #8 |
Then the reason we require dz/dt=dx/dt+idy/dt is nonzero is, i believe, to make sure the path is well-behaved, i.e. we can always bijectively parametrize the path locally,or in other words, in a small enough region there always exists a function y=f(x) or x=f(y), this is guaranteed by the implicit function theorem. This is also analogous to the line integral in vector calculus, look at the definition here: http://en.wikipedia.org/wiki/Line_integral#Definition "where r: [a, b] → C is an arbitrary bijective parametrization of the curve C such that r(a) and r(b) give the endpoints of C." EDIT: wait a minute, now im not so sure about nonzero dz/dt will guarantee implicit function exist, let me think it through |
| Apr10-10, 05:35 AM | #9 |
The second definition is more general, but when the function is analytic, the first and the second will be the same. |
| Apr10-10, 10:45 PM | #10 |
Also,for any point,isn't there always some y=f(x) or x=f(y)?It seems to me that even if the derivative at the point is zero,we could have some y=f(x) and x=f(y)...for example y=(x)cubed...it has a zero derivative at 0...but we still have an explicit definition of y=f(x). |
| Apr10-10, 10:53 PM | #11 |
....then why did he need to bring in path independance and all that? Besides,if integration is defined for a function,the antiderivative must be defined....then why did hw have to make a separate theorem for that? |
| Apr11-10, 01:56 AM | #12 |
see here: http://www.applet-magic.com/implicit.htm But the thing is, now i don't think nonzero dz/dt would for sure define such a "well-behaved" curve, so i am not sure why it is required |
| Apr11-10, 02:19 AM | #13 |
In short, take the second as the definition and the first as a theorem |
| Apr12-10, 07:47 AM | #14 |
If I start out with the second one,and put f(z) as an analytic function and the region as a simply connected one,then we would automatically arrive at the first one....since the integral is independant of the path..and as you said,he says its and indefinite integral,simply to emphasize that the antiderivatives are well defined at each point....and ofcourse,if we put the antiderivatives within limits,it can easily be made a definite integral. |
| Apr12-10, 07:50 AM | #15 |
| Apr12-10, 08:10 AM | #16 |
Sorry,kof9595995 ,
I posted these questions on another forum,but noone replied...and again,I'm pretty desperate to find out the answers to these....please could you give a try? Sorry for the botheration.... 1. If we have an annulus on a complex plane,is the entire region within the inner circle a set of singularities? 2. An isolated singularity is said to be a point such that there are no other singlularities in its neighbourhood....such a singularity exists only when the principal part(the part of the laurent series with the negative powers) is an infinite series.....please state the reason as to why this criteria exists. 3.The residue at a point is said to be the coefficient of the first negative term in the laurent series...how ?(please give atleast a sketch of the proof). 4. What is the significance of a residue on a complex plane?(i.e How does the function behave differently at a residue?) 5. How are poles different from other singularities?(my book says functions behave differently around poles and other kinds of singularity...why?) |
| Apr12-10, 12:47 PM | #17 |
That said, there aren't strict rules on how the word singularity is used outside the context of isolated singularities. I would very much advise that you do not use it in this context, though. Are you looking for a proof of the residue theorem? That is something you could find in a textbook; it's not suitable for me to reproduce such a proof here. g does not vanish identically, so a is a zero of finite order, say h. Hence by Taylor's theorem with remainder g(z) = (z - a)^h * j(z) where j(a) != 0. f now has the representation f(z) = (z - a)^(-h) * k(z) where k(z) = 1/j(z) is analytic and nonzero in a neighborhood of a. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Complex integration.
| Complex Integration | Calculus & Beyond Homework | 2 | ||
| complex integration | Calculus | 1 | ||
| complex integration z^0.5 | Calculus & Beyond Homework | 19 | ||
| complex integration | Calculus | 6 | ||
| Complex integration | Calculus & Beyond Homework | 7 | ||
