HDMI / Component Video Switches
The discussion revolves around the setup of an HDTV system, specifically focusing on the use of HDMI and component video switches and splitters to manage multiple televisions. Participants explore the feasibility of outputting signals from gaming consoles to multiple TVs without losing quality.
  • One participant seeks a solution to output signals from a PS3/Wii to two TVs without switching wires, expressing concern about potential quality loss when splitting component audio/video signals.
  • Another participant confirms the existence of component-video switches and suggests a reputable source for purchasing such equipment.
  • A different participant clarifies that their need is not for additional inputs but rather for splitting the signal to two TVs while maintaining quality, questioning whether splitting would result in signal loss.
  • One participant mentions that component-video switches can pass signals in both directions and suggests that Monoprice offers component-video splitters, although they express uncertainty about their effectiveness in this scenario.
  • Another participant proposes trying a cheap splitter first to evaluate its performance before considering a switch used in reverse.
  • A participant shares their experience using a plain A/V switch for component video, noting that RCA connectors can be utilized for both audio and video connections.
Participants express differing views on the effectiveness of splitting signals and the potential for quality loss. There is no consensus on the best approach or equipment to use for the described setup.
Participants discuss the limitations of their current setups and the specific needs for their configurations, but there are unresolved questions regarding the quality of split signals and the best hardware solutions.
minger
HDMI / Component Video "Switches"
Hi guys, I just entered the HDTV realm and I'm having a little difficulty setting up my system. I don't have any place to put old extra TVs, so I have three (no, the girlfriend doesn't like it) TV's basically side by side.
Are there splitter switch things so that I could output my PS3/Wii to 2 of the TV and use a box or something to chose which TV it goes to?
Basically I'd like to be able to use everything on the new TV, but if it's in use, I'd like to be able to hit a switch and output it to one of the auxiliary TVs without switching wires which is what I'm doing now and I think it bush league.
Thanks a bunch,
edit: Actually only the new TV has HDMI input, so I would only need to "split" the Wii's component audio/video. I would think that simply splitting them would lose quality/signal. Am I correct in this thinking?
Computer science news on Phys.org
Yes, there are such things as component-video switches. I used one myself for a while before I converted all my HD connections to HDMI. Here's an example:
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10112
I didn't actually use this one, but I bought my current HDMI switch from this company, and they're well-regarded as a source for good, inexpensive audio/video cables, connectors, switches, etc.
I think that's the opposite of what I want. I don't need "extra" inputs or expand the number of inputs my televisions I have; I have plenty.
Rather I'd like to be able to output the signal from my Wii to two televisions without loss of quality. I suppose the first question before hardware would be if simply splitting the signal of the component audio/video will result in losses of quality/strength?
As far as I know, component-video switches can pass the signal in both directions, so they should work for what you want. It's simply that most people use them as I did, to allow more than one device to use a single input on a TV.
You won't be able to watch the same thing on more than one TV, of course.
Monoprice also sells component-video splitters, but I don't know how well one would work in your situation.
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10422
Maybe the solution is to pick up a cheap splitter and see how well it works. If it doesn't work well, try picking up a switch and use it in reverse.
Thanks,
I have used a plain old A/V switch for Component Video. They both use RCA connectors and the L/R audio connectors could be used for video. In this case the audio was going to stereo and not the television. The stereo had enough inputs so each source has it's own connectors.
13K
13K
  • · Replies 26 ·
