Electric Generators: Iron Core for Larger Current?
  • Context: Undergrad
  • Thread starter Thread starter nbsmith
    Electric Generators
The discussion centers on the impact of using an iron core in a solenoid for generating electricity. It is established that while an iron core enhances the magnetic field when current flows through it, it does not increase the induced current when exposed to a changing magnetic field. Instead, the permeability of the iron core results in a smaller induced current compared to a hollow core, due to its higher permeability value. This conclusion is supported by Ampere's law, which indicates that the induced current is inversely related to the permeability of the core material.
  • Understanding of Ampere's law and its application in electromagnetism
  • Knowledge of magnetic permeability and its significance in solenoids
  • Familiarity with the principles of electromagnetic induction
  • Basic concepts of electric circuits, including Ohm's law
  • Research the principles of electromagnetic induction in detail
  • Explore the effects of different core materials on solenoid performance
  • Study the design and construction of electric generators using coils and magnets
  • Learn about the role of insulation in solenoid wire and its impact on current flow
Engineers, physics students, hobbyists interested in building electric generators, and anyone seeking to understand the relationship between magnetic fields and induced currents in solenoids.
nbsmith
I know that the iron core of a solenoid will result in a higher magnetic field than a hollow core when a current is running through it.
I'm wondering if the reverse is true. Will an iron core result in a larger current when the solenoid is exposed to a changing magnetic field?
I want to create a simple generator where one or two electric coils are rotating between some magnets and I am wondering if having an iron core will create a larger current.
Any explanation as to why would be appreciated too.
Thanks.
Thanks.
Let's see here. We have the following from Ampere's law:
B = mu NI/h
Solving this for the current, we get:
I = Bh/(N mu)
Where mu depends on the core material. Using iron (or most other metals) this value will be greater than mu_nought = 1/(4pi x10^-7) ~ 1.2566650×10^-6.
The movement of the core inside the solenoid causes a changing magnetic field ([tex]\hat{B}[/tex]) which causes an induced current (I). As such, the current depends on the changing magnetic field, as well as the permeability of the space inside (our mu.) As mu_iron > mu_hollow, where mu_hollow=mu_nought, we will get a smaller induced current using an iron core from the same changing magnetic field, [tex]\hat{B}[/tex]. This would mean changing the position of the core inside of the solenoid by the same amount and at the same rate.
So, if the changing magnetic field is the same in both trials (one with a hollow solenoid, one with an iron core) we get a larger induced current using a hollow core as a result of the smaller permeability value. As such, we will get a smaller induced current when using an iron core as a result of its larger permeability value.
Since there is the above exposition, I'll just add in simpler language also that the added resistance of the iron core, if the solenoid is formed of uninsulated wire so there is contact, will add to the resistance of the system and therefore reduce current flow per "V=P/I."
This rarely has any purpose to be considered since most solenoids are insulated... but... life happens.
  • · Replies 43 ·
  • · Replies 18 ·
  • · Replies 60 ·
  • · Replies 74 ·
15K
