How to define the b.c.s for the EM field of a perfectly contucting surface?
  • Context: Graduate
  • Thread starter Thread starter sith
    Em Field Surface
The boundary conditions (b.c.s) for the electromagnetic (EM) field of a perfectly conducting surface are defined by the equations: \boldsymbol{E}_{\parallel} = 0, B_{\perp} = 0, E_{\perp} = \frac{\sigma}{\epsilon_0}, and \boldsymbol{B}_{\parallel} = \mu_0 \boldsymbol{j} \times \boldsymbol{\hat{n}}. Here, \sigma represents the surface charge density and \boldsymbol{j} denotes the current density at the boundary. These conditions derive from Maxwell's equations, assuming the EM field vanishes inside the conductor. However, for a planar conducting surface, as the height approaches zero, the separation of surface charge and current densities becomes unified, raising questions about the validity of these conditions and their potential modification based on thickness and conductivity.
  • Understanding of Maxwell's equations
  • Familiarity with electromagnetic field theory
  • Knowledge of surface charge and current density concepts
  • Basic principles of conductivity and skin depth
  • Study the implications of Maxwell's equations on boundary conditions
  • Explore the concept of skin depth in conductive materials
  • Investigate modifications to boundary conditions for varying conductivity
  • Examine the behavior of EM fields in thin conductive layers
Electromagnetic theorists, electrical engineers, and physicists interested in the behavior of electromagnetic fields at the boundaries of conductive materials.
sith
If you have a 3 dimensional perfectly conducting body the conditions at the boundary for the EM field is as follows:
[tex]\boldsymbol{E}_{\parallel} = 0, B_{\perp} = 0, E_{\perp} = \frac{\sigma}{\epsilon_0}, \boldsymbol{B}_{\parallel} = \mu_0 \boldsymbol{j} \times \boldsymbol{\hat{n}}[/tex]
where [tex]\sigma[/tex] and [tex]\boldsymbol{j}[/tex] are the surface charge and current density at the boundary respectively. [tex]\parallel[/tex] / [tex]\perp[/tex] denotes the component parallel/perpendicular to the surface of the body, with normal vector [tex]\boldsymbol{\hat{n}}[/tex]. The derivations of these boundary conditions comes from assuming that the EM field vanishes inside the conductor and using Maxwell's equations. But when one assume that the body is a planar conducting surface, there is no longer a finite volume in which the EM field vanish. If you for instance take a conducting box, and then study the limit where the height goes to zero, then the top and bottom surface charge and current densities can no longer be separated, and they are unified in one overall surface carge and current density. Can one still assume that these conditions are true, or should they be modified in some way? Could it be possible that these conditions are instead only valid for the differences between the fields on each side of the surface?
If it is a perfect conductor, then the BC hold for thickness-->0.
If it has a very high conductivity, then the "surface current" and the E and B fields will vanish exponentially. Then as the thickness approaches the skin depth, the BC would get modified.
  • · Replies 22 ·
