Photon-to-baryon ratio from CMB structure details?
  • Context: Graduate
  • Thread starter Thread starter hkyriazi
    Cmb Ratio Structure
The discussion revolves around the determination of the photon-to-baryon ratio from the detailed structure of Cosmic Microwave Background (CMB) fluctuations. Participants explore the relationship between CMB analysis, sound horizon, and the implications of baryon density, as well as the assumptions underlying these analyses.
  • One participant questions how the photon-to-baryon ratio is determined from the CMB structure, specifically referencing the spatial Fourier transform peaks.
  • Another participant explains that the first peak in the CMB relates to the sound horizon at last scattering, which is influenced by the baryon-to-photon ratio.
  • A follow-up question addresses the dependence of this analysis on the density of photons and baryons required for nucleosynthesis.
  • One participant expresses the view that CMB analysis does not depend on Big Bang Nucleosynthesis (BBN) and suggests that they yield consistent results independently.
  • Further inquiries are made regarding the assumptions of real expansion and the implications for the density of matter and photons at the time of the CMB's formation.
  • Another participant asserts that WMAP results rely on the assumption that the universe described by the perturbed Friedmann-Robertson-Walker (FRW) metric is accurate, implying that the expansion is real.
Participants express differing views on the dependence of CMB analysis on BBN and the assumptions regarding the universe's expansion. There is no consensus on these points, indicating ongoing debate and exploration of the topic.
Participants highlight various assumptions regarding the density of baryons and photons, the nature of sound speed in the early universe, and the implications of an expanding universe on the interpretation of CMB data. These assumptions remain unresolved within the discussion.
hkyriazi
Not sure if this is an easy question or not.
The Wikipedia entry on the Big Bang, in its section on "Abundance of primordial elements," cites the 1988 book by Kolb and Turner (The Early Universe), in saying that the ratio of photons to baryons "can be calculated independently from the detailed structure of CMB fluctuations."
I assume by "structure" they mean its spatial Fourier transform peaks, as shown in the Wikipedia article on CMB, under "Primary anisotropy" - the graph is titled "The power spectrum of the CMB radiation temperature anisotropy in terms of the angular scale (or multipole moment)."
The question is, how do they determine that photon to baryon ratio? (I thought I might save myself the trouble of going to a library and consulting Kolb and Turner.)
Space news on Phys.org
Very roughly speaking: The first peak in the CMB corresponds to the size of the sound horizon at last scattering, as it is the largest coherent structure in the universe at that time. The sound speed at last scattering is not the usual c / sqrt(3) for a photon gas, but rather it is less because the plasma is "weighed down" by baryons. The sound speed directly depends on the baryon to photon ratio.
Thanks, Nick. Googling "sound horizon at last scattering" gave me lots of sites to explore. One further question while I've got you on-line. How much of this analysis depends on the actual density (of photons and baryons) being taken to be that which is required for nucleosynthesis (and which can be inferred from the Hubble Constant and taking time back to the presumed beginning)?
My interpretation is that CMB analysis doesn't depend at all on BBN, and they completely independently give consistent results. However, I do not claim to be an expert and I could very well be wrong.
Thanks again, Nick.
Nick, I apologize for dragging this on, especially when further rumination on my part might allow me to answer my own questions, but one more question occurred to me that you may be able to answer easily. Do you think the CMB analysis depends on the assumption that the expansion is real, and therefore that the matter and photons we assume produced the CMB were, at ~13.7 billion years ago (BYA), much more densely packed in space than they are today? In other words, is there anything inherent in the blackbody radiation, and its spatial variations in temperature, that says "this is due to baryons having X spatial density, and photons having 10,000,000 (or whatever) X"? Moreover, the "sound" speed they're using is undoubtedly geared toward a distance scale, 13.7 BYA, that is much smaller than one would assume for a non-expanding universe. Those are some of the assumptions I assume they made. Without those, I assume the explanation for the structure of the inhomogeneities would be quite different. But, I assume a much more diffuse gas could also display oscillations on a much larger scale somehow.
I believe it is correct to say that any WMAP results rely on the assumption that the universe described by the perturbed FRW metric is "true" (i.e., that the expansion is real), and those results give best fit parameters to that universe.
  • · Replies 80 ·
17K
