Is 1466996987 a Prime Number? Factors and Verification
  • Thread starter Thread starter smslca
    Prime
The discussion revolves around the determination of whether the number 1466996987 is a prime number. Participants are exploring methods to verify its primality and identify any factors if it is not prime.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss dividing the number by primes below fifty as a method for verification. There are mentions of specific divisors found, such as 29 and 43, and suggestions to use online tools like Wolfram Alpha for factorization.
The discussion is active, with participants sharing their findings and methods for factorization. Some have confirmed divisibility by certain numbers, while others are exploring different approaches to verify the primality of the number.
There is an emphasis on using external resources for verification, and some participants express uncertainty about the methods they should use to check for primality and factors.
Try dividing it by every prime below fifty. You'll find out whether you're right or wrong...
thank u
its divisible by 29,43
And one other, but if you want to find that one, just divide your original number by (29*43).
how can i know divide it by primes below 50 or other
Go to the website Wolfram Alpha and type "FactorInteger 1466996987" into the input box. Then you know.
I didn't even type FactorInteger...
If you type in 1466996987 into the input box, it will give you all kinds of properties about the number... including prime factorization.
Yeah. I should have known. There was method to my madness. I used Mathematica Information to find the operator used to factor primes, then figured Worlframe Alpha would recognize it too.
I just tried factor 1466996987 from command line. But even factor(1466996987) on TI-89 gives answer almost immediately.
12K
  • · Replies 36 ·
  • · Replies 32 ·
10K
