Absorbing Material Over a Slit in Deriving Double Slit Fraunhofer Interfernce Pattern
The discussion focuses on deriving the Fraunhofer interference pattern for a double slit experiment where one slit is covered with an absorbing material. The equation presented is I(θ) = [I(0)/K][(Sin(β)/β)²(1 + c² + 2cCos(2α))], where K is a constant that needs to be determined. The user deduces that K = (1 + c)² by evaluating the equation at θ = 0 and applying L'Hôpital's rule. The challenge lies in correctly incorporating K without negating the amplitude effect of the absorbing material.
  • Understanding of Fraunhofer diffraction principles
  • Familiarity with complex notation in wave equations
  • Knowledge of the sinc function and its properties
  • Basic calculus, including L'Hôpital's rule
  • Research the derivation of the Fraunhofer diffraction pattern for single and double slits
  • Learn about the impact of absorbing materials on wave amplitude and intensity
  • Study the application of L'Hôpital's rule in evaluating limits in physics
  • Explore the use of complex numbers in wave mechanics and optics
Students and educators in physics, particularly those studying wave optics and interference patterns, as well as researchers exploring the effects of material properties on light transmission.
Ajihood
In class we have been deriving the Fraunhofer interference pattern for a double slit experiment. I now have a question of having to derive it if one of the slits is covered with an absorbing material. I have got the equation out but I am missing a constant K...
We have two identical slits of width b whose centres are separated by a distance a. Now suppose that one slit is covered with an absorbing material, so that it transmits less light than the other slit.Assume that the absorption only affects theamplitude of the light transmitted by the affected slit, multiplying the electric field amplitude by a factor c, but does not affect the phase. It can be shown that the Fraunhofer intensity pattern is given by:
I([tex]\theta[/tex]) = [[tex]\frac{I(0)}{K}[/tex]][([tex]\frac{Sin(\beta}{\beta}[/tex])]2[ 1 + c2 + 2cCos(2[tex]\alpha[/tex])] That alpha is not ment to be superscript but I can't get it out.
(a) What is the value of K?
(d) Derive the above equation. Hint: Assume that the unaffected slit is centred at the origin, and that the other slit is centred at x = a. Stay in complex notation as long as possible.
Where K is a constant
[tex]\beta[/tex] = ub/2 = (1/2)kbsin([tex]\theta[/tex])
[tex]\alpha[/tex] = ua/2 = (1/2)kasin([tex]\theta[/tex])
(a) I think this is relatively simple. I let [tex]\theta[/tex] = 0 into the equation above. Then used Le Hopitals rule/ looked at the sinc function and found K = (1 + c)2
(b) Now the problem here is that I can derive the above equation with no problems but I am missing the constant K! Do I introduce it as a normalising factor? I don't know where it comes in :(
Here is the summary of my derivation
E(u) = A[tex]\int[/tex] eiux dx + Ac[tex]\int[/tex] eiux dx
Where the first integrand has goes from -b/2 to b/2 and the second intergrand goes from a-(b/2) to a+(b/2)
Integrating and factorising I get
(A/iu)(eiu(b/2) - e-iu(b/2))(1+ceiua)
Now using Euler's Formula and introducing the idenity [tex]\beta[/tex]
Ab([tex]\frac{Sin\beta}{\beta}[/tex](1 + Ceiua)
Now squaring to get intenisty/irradiance, making sure to muliply by the complex conjugate and using Eulers formula to introduce Cosine and Alpha
I = A2b2([tex]\frac{Sin\beta}{\beta}[/tex])2(1 + c2 + 2cCos(2[tex]\alpha[/tex]) Where alpha is not in superscipt.
So assuming I(0) = A2b2 I have the above equation without K!
So I don't know how I am going to get that (1 + c)2 factor in there??!
Maybe I(0) = (1 + c)2A2b2 ?? But then the absorbing material won't affect the amplitude would it?
Thanks for any help! :)
I guess no one can help :( I am going to run with I(0) = A2b2(1+c)2 I find this when I put [tex]\theta[/tex]=0. Thus I have to introduce K as a denomiator to cancel the (1+c)2.
The only problem I have with that is that I swear it looks like it will cancel c's effect on the amplitude...
  • · Replies 33 ·
