Water Pump System: Choosing the Right Electrical Motor
  • Thread starter Thread starter Eng_Luqman
    Pump System Water
The discussion focuses on selecting the appropriate electrical motor for a water pump system in a factory setting. The specifications provided include a 3-phase induction motor with 2900 RPM, 5.5 kW, and a water pump with 3600 RPM, 6 HP, and a head of 30 m. It is established that the motor's power must equal the pump's power divided by its efficiency; thus, a motor rated at 7.5 HP is recommended for a pump with 80% efficiency. Additionally, the RPM of the motor and pump must be matched, or speed adjustment mechanisms like gears or belts should be employed.
  • Understanding of 3-phase induction motors
  • Knowledge of pump efficiency calculations
  • Familiarity with hydraulic systems and head pressure
  • Basic principles of mechanical power transmission
  • Research "Pump Efficiency Calculation" to understand how to determine the required motor power.
  • Learn about "Mechanical Power Transmission" methods, including gears and belts.
  • Study "3-Phase Induction Motor Characteristics" for better motor selection.
  • Explore "Hydraulic System Design" principles for optimizing pump and motor compatibility.
Engineers, factory managers, and technicians involved in the design and maintenance of water pump systems, particularly those optimizing motor selection and efficiency in industrial applications.
Eng_Luqman
Dear ...
Please Try To Read Those :
I have This System Of Water Pump Consist Of An Electrical Motor And A Water Pump For Lifting Water From An Underground To The Upground ... In A Factory Using This Pumped Water For Cooling The Iron That Produced Form The Rolling Machines ... (( Open System - To The Atmosphere )) .
And The Main Thing I Want To Know It ... Is To Be Sure Is This System Is Working Correctly With The Bellow Specifications :
Electrical Motor Specifications :
RPM = 2900
V = 380
P = 5.5 Kw
F = 50 Hz
A = 10
3 - Phase Induction Electrical Motor
Water Pump Specifications :
RPM = 3600
P = 6 HP
H = 30 m
Q = 1000 L / Min.
The input and out put line of the pump = 3 inches Pipe
The thing that I want to know it exactly ... how they choosing the this Electrical Motor For This Pump ... Is That Correct ...
On What Formula They Depend ... Or On What Base They Depend To Choose This Electrical Motor For This Water Pump ...
You Can See The RPM For Both Of The E.M. And The Water P.
And How They Arrange The Both ... ?
Hope I can get the right answer and helping to understand the bases and the formulas also in details ...
Regards
They are not perfectly matched. The critical parameter is power. The output power of the motor must equal the power of the pump divided by pump efficiency. For example, if the pump is 6 HP, and its efficiency 80% then it needs 6/0.8 or 7.5 HP of power from the motor. 7.5 HP = 5.6 kw. So the 7.5 kw motor is slightly larger than needed.
Either the two RPM must be exactly the same, or some gears or belts are needed to change the speed. In your case, the pump probably runs at 2900/3600 or 80% of its rated speed, making the HP and L/sec lower.It sounds like you expect both motor and pump to run at exactly the nameplate values listed. The values are maximums. You probably drive a car rated at 120 mph, but you don't really drive it that fast.
  • · Replies 19 ·
10K
  • · Replies 23 ·
